all you gotta do is flip the cover on the interior door hadle off, do this with a flathead screwdriver or sumthin, then undo the two screws hidden behind the cover and then the card is basically held on by clips and the card should come off with a small amount of force. hope this helps!
right ive done this 5 times this week replacing my window mech so im gettin good.
flip off the grab handle cover and undo the 2 screws
then take a screwdriver to the winder handle,place it behind the handle and slide the trim ring up from it, youll see what i mean, this will then pull off.
then get a large flat blade or pry bar and insert under the edge below the pocket and pull CAREFULLY
then the rest will pop off
willriseley wrote:right ive done this 5 times this week replacing my window mech so im gettin good.
