http://www.lumileds.com
Not sure about a UK source for them though.
9N - Connecting the LHS rear fog light
Re: 9N - Connecting the LHS rear fog light
i Want to do this on my 9n3, but on my RHS light which the fog is held in, it has like a red plastic casing in that lense section(which gives it its red fog colour) and in the LHS light there is no red plastic casing in that lense thus it just gives off a white light for the reverse.Guest wrote: VW supply a Dual Filament bulb, so you just need the connecting wire.
i would love to be able to switch the fogs on and both sides light up red, and when i put it into reverse both sides light up white.
my lights have two bulbs in the main brakinging light - hot plate aera. then in the lower segment of the light it is split in two with one bulb for the indicator and another bulb for either fog or reverse light
