Golf 4 clocks in 6n
Golf 4 clocks in 6n
how easy is this to do with all the parts and adaptors?
the wiring of the pins etc?
any ideas any one or any one done this?
Right,
This mod in on my medium, long term plans, so I'll share the info i already collected about this.
first: it can be done:
Next, not all Golf IV clocks ( tachos) will work. I believe they must have ohne can bus. But you should investigate this by yourself. But i'll check with more people who have already done this.
Fitting the tacho, you will have to get a small bar, where the old tacho sits on. You dont have much space there, but it will fit.
The adaptor, should do his work. It's plug and play, it seems. You should check if the plug is plug and play on both sides or if its prepared only for one end and you will have to connect all the other wires to the other side.
But that is easy, since you have a guide, its just a question of pluggin in the right wires
the schematics goes like this ( in portuguese, but i can translate)
T28/1 - Azul/7, 6, 9, 19, 24 - MASSA
T28/2 - Azul/22 – Indicação da Ã
Right,
The adaptor your getting should come with the schematics of what connects to what. but if required i'll translate this and PM you.
Oh, and check if the adaptor is for the older or newer clocks on the polo. As you know, the clocks changed from 98 onwards.
polo_dude, that picture is not of my car. Even though i also have red lighting in my buttons ( currently doing the conversion!)
For the heater controls, it's pretty simply actually:
You can change either the bulbs or the plastic that gives the colour. For perfect results you should change both.
Here's the pics from a small DIY available at the dutch polo club http://www.vwpolo.nl/
The template required:
Download here
Download here
Sorry to bring up an old post but this is rhe translation for the above:
T28 / 1 - Blue / 7, 6, 9, 19, 24 - MASS
T28 / 2 - Blue / 22 - Indication of Water Fuel
T28 / 3 - Blue / 7, 6, 9, 19, 24 - MASS
T28 / 4 - Green / 25 - MFA Reset and Memory
T28 / 5 - Blue / 7, 6, 9, 19, 24 - MASS
T28 / 6 - Green 30 - Output speed
T28 / 8 - Blue / 10 - Pressure of Oil
T28 / 9 - Ignore
T28/10 - Blue / 11 - Speed
T28/11 - Blue / 23 - Positive Constant (12V)
T28/12 - Blue / 20 - Lighting
T28/13 - Blue / 1 - Positive Ignition (12V)
T28/14 - not placed
T28/15 - Green / 23 - MFA call key,
T28/16 - Blue / 12 - Light of the Alternato
T28/17 - Green / 18 - Temperature of the oil and Notice
T28/18 - Green / 13 - of Hand Brake
T28/19 - Green / 26 - Temperature Outside
T28/20 - Blue /13 - Light of Resistance
T28/21 - Blue / 5 - Indication of Fuel
T28/22 - Blue / 18 - left Flashes
T28/23 - Blue / 8 - indicator of the temperature of liquid cooling
T28/24 - Blue / 2 - right Flashes
T28/25 - Blue / 17 - Maximum
T28/26 - Green / 32 - Consumer Signal
T28/27 - Blue / 28 - Sign of Speed
T28/28 - Free
T28 / 9 - Ignore
T28/14 - not placed
T28/28 - Free
@DUB can you please tell me where did you bought that adapter ? ?
i saw on ebay for 50 €, that is a lot, is it possible to built it at home ? what connectors should i buy from VW ?
i dont get it where i connect the end with pins and where wires are going ?
and can someone explain this for ex
T28/2 stands for ?
Blue is wire but 22 is ? this side conects to golf 4 tacho or ?
i am little stupid please help !
thanks
T28/2 stands for ?
thanks
Yes they are standard But the colour is Green !
Only 6n GTI has Blue tacho[/quote]
yes that becuase of the coloured stip in the top of the clock being green
like the heater dials
the newer vw had blue not green
as did the seats have red
go to the scrap yard get polo clocks and a golf blue light strip
yes that becuase of the coloured stip in the top of the clock being greenBratManGTi wrote:Yes they are standard But the colour is Green !
go to the scrap yard get polo clocks and a golf blue light strip[/quote]
yes i think you are right i don't know exactly.
But it is easyer to buy tacho from G4 then from Polo new type tacho !
i have old one so it is the same for me !
i think i will go with g4 tacho
