6n, fitting GT camshaft
guys. im confused here. i went to a garage earlier to get a price for a mechanic to fix one of these for me. n they said you cant just fit the camshaft to a normal enginee. as it would strain the springs which old the valvs or summit. what parts did you exactly change:S just the pulley cogg thing??
wouldnt this strain the cam belt??
What you mean by "strain the springs"?
I just swapped the camshafts, got my old one out, then putted the GT one in, no other mod's needed, it's a straight swap, and if any tw*t tells you it can't be done, tell him he's the dumbest mechanic ever known to mankind cause it's already been done many times, with succes
It really isn't hard, just:Pedro_Hilario wrote:I really need to do this to my 1.3 in the future. But after some other mods ( BBS, mainly!)
If anyone does this in the meanwhile they should take a step by step pictures to make it easier to do the mod!
Pedro
take the valve cover off
take the distributionbelt cover off
loose the distributionbelttightener
take out the old camshaft (make sure it's "loose" from the ignition
swap the camshaft pulleys
put in the new GT cam (make sure to "hook it up" to the ignition, and to keep in mind the markings for the timing of the cam, which is on the pulley and the block)
put back the distribution belt
tighten the belt
put back all covers
rotate the crankshaft couple of times to make sure no valves hit the piston
And voila, enjoy your GT cam
(ok, this is a very "brief" explaination of the works, but buying yourself a Haynes manual will get you a looooong way in understanding what I describe here, Haynes manuals are the best investment you can make for your car )
Yeah,
I got a Haynes Manual, it already saved me alot of money with simple things that can be done to car and avoid the expensive garage. And here in Portugal, you just cant find a decent and honest mechanic!!!
I'm thinking of doing this next summer, so if I have any questions I'll ask at that time.
Pedro
Pedro
it shouldnt damage the valves, i dont think the lift is any higher as the lobes look the same, but i didnt measure. It just has a longer duration.
bit more in depth guide but it is off the top of my head
jack the car up on the offside, remove the front wheel and the cover on the bottom of the arch.
use a jack and bit of wood under the sump to support the engine(no wood means pain in the ass when the jack goes through the sump), remove the engine mount. jack the engine up to get to all the nuts and clips off the timing belt cover. lower the engine on the jack.
release the bolt on the alternator which allows you to tension the belt(sort of like a slider), lever off the engine to push the alternator down to slip the serpentine belt off. Remove the 4 allen bolts holding the serpentine belt pulley on the bottom of the engine, you can then see the crankshaft pulley.
Use a multi-sided spanner to turn the engine over clockwise until the arrow on the bottom crankshaft pulley is pointed upwards towards a marker and the mark on one of the teeth on the camshaft pulley is lined up with its marker (you can see in the pic). This is when n.o 1 piston (piston closest to the timing belt) is firing, both its valves are closed and the lobes on the camshaft are pointing upwards.
Release the timing belt tensioner and slide the belt off the camshaft pulley. jam a f off breaker bar or similer tool in the camshaft pulley and release the nut, taking off the pulley.
take the rocker off then all the 'shells' (not sure if its the right word) off to get the old camshaft out. Put the gt camshaft in a similar position to the original with both lobes pointing upwards, put all the shells back on and the camshaft pulley back on. Make sure your lower crankshaft pulley is still lined up. slip the belt back on the camshaft pulley making sure its sitting on all the pulleys correctly.
Use a allen key to get the tensioner in the correct position, lined up with its crazy markings and do up the nut. Turn over the engine clockwise on the bottom pulley to make sure the valves and pistons dont make sweet love. You can then use a long screw driver through the sparkplug hole on n.o 1 piston to get the valves opening at the best times. quote from yoof "I always set cams up by locating TDC and then measuring when max lift is on no.1 cylinder and adjusting timing to suit, usually 110degrees after"
Then just throw everything back together, the ignition timing needs playing with as well.
He means the cam itself? Or the valvesprings?Hardcore wrote: them little springs which hold the valves open and close them.
complete bullsh*t, the lift isn't that much higher, just slight fraction, mostly the gain comes from longer duration, which isn't enough to give a noticeble extra pressureHardcore wrote: all the pipes would be under more pressure and strain.
Go find yourself a decent mechanic m8
Of course, or else it won't fit m8 you can't really see the difference if you don't know what to look for, just make sure there's 030 AF engraved in it.Hardcore wrote:im tyring to lol.
anyone wana be my mechanicn who lives near derbyshire
and i fink he means the valvesprings m8y.
by the way. you know the camshaft im looking for. is it the same size as the one im replacing it with??
