Polo 9N Pollen Filter Clean / Change.
This is an easy thing to do. The filter is located under the passenger side dash.
To remove simply slide the two tabs into the centre which release the cover plate.
Then its just a matter of pulling gently downwards on the filter.
Mine was a little stiff but came with a bit of work.
A quick pat and blow out to remove the dirt and then it’s a matter of guiding the filter gently back into place and placing the cover plate back over the top.
If the filter is looking really bad its time to replace it.
Old and new filter side by side.
The car had only done 30,000km and it looked like this.
- whitegtipolo
