Shortening Door Pins 6N2
neilGTI
Post by neilGTI »
Using just a pair of pliers, this mod only takes a few minutes to complete.
All you have to do was to unscrew the door pin, cut down the metal bar using the pliers and then put the door pins back on.
I used glue dots to stick the pins back on, but blue tack would do as well. You will only be pushing these down and you will never be pulling on them because they will be sitting flush when locked and you dont need to pull on them for any reason when the car is unlocked ;)
I dont accept any responsibility if anyone fluffs this up.
