How to change engine oil (6n2)
revolutionrock
Post by revolutionrock »
A small guide, for those who do not know...
http://18-revolutionrock.50webs.com/polo.htm
Going to make guides about how to change oil sump seal and selector shaft oil seal :)
/Johan
Bepe
Re: How to change engine oil (6n2)
Post by Bepe »
your guide to change engine oil is wrong :)
Dont start your car, before changing oil, let the car cool down not complelty cool, give it 10minutes or so, and all the oil from the top of the block will drain into the sump(you will be draining this) and the oil wont be HOT! and your supposed to change the sump plug+washer too.
revolutionrock
Bepe wrote:your guide to change engine oil is wrong :)
There is nothing wrong to have the engine hot!
no need to change oil plug if it is good, washer should be change...
Feeblington
Drives: 6n2 1.4 se
Post by Feeblington »
My sump bolt wont budge :( i jacked rear of car up and removed filter. Could only get about a litre of oil out.
Fail!
Best to use a suction device down the dipstick in that case then
