MK3 Clocks Removal
MK3 Clocks Removal
I've had problems in the past with removing the clocks and I didn't really know what I was doing untill I asked people a few hundered times what i was doing. But I still managed to break stuff (some how my digital clock is broken ah well)
Firstly you need to get hold of the clips that will enable you to pull the clocks out. You can always make it out of an old coat hanger like I did
(Note the sexy seat colours )
Remove the radio and the block encasing it so you can get beside the clocks at the back
You then need to remove the crappy plastic cover around the steering column.
Take the screws from underneath the column first.
THen try and prise the top plastic bit off
This is probably the hardest bit of the hole thing, in that it's aquward. There is a small prong/clip going into the steering column which keeps it in place you may be able to get it off by just pulling the right way (which mine now does), but if it hasn't been off before it will be a bit harder and taking a screw driver to it is a good idea (after about 30mins you may feel like getting a sledge hammer at it but... )
Once that's off, take the prong things. And put them in the clocks
At this point it easily come out, in the case that it doesn't get a screw drivers and push in the grey prongs whichare behind the radio on the left hand side of the clocks.
You'll then need to get the loom connector out of the back of your clocks, to do this you need to push the clip down and pull on the wire.
After that's out I HIGHLY recommend getting the casing for the lights out. A screw driver should easily prise it out.
Then you can undo the screws on the back... Done
- Sponsor
Can't say I've heard it being done before. In theory it could work, as long as the connector plug on urs will match up with the socket on the mark3 clocks. There is also the obvious dimensions, but seen as the mark3 dash is only slightly changed from mark2, there shouldn't be an issue. All I can suggest is give it a go.
Karl.
Karl.
Just found this on my travels. Guy there reckons that you can't fit a mark3 set of clocks into a mark2 dash. You have to change the complete dashboard for the mod to work. All you would be able to do is fit mark2 Coupe S dials (with rev counter) into yours I'm afraid.
http://www.porka.net/modules.php?name=X ... &tid=19248
- Sponsor
im currently doing this at the moment, havent got a 23mm socket to get the sterring wheels off tho, so i cant get the mk3 dsah completly out but i it all seems to share the same mountings and stuffmain things gonna be these clocks, if the dont share the same conectors/plugs shouldnt be to much of a job to change em. ill let ya no how it goes
- Sponsor
Excellent, yeah, let me know Does the wiring loom in the mk3 dash use the same connectors to connect to the rest of the car? If so, I would have thought it's a simple job just to plug the mk3 clocks into the mk3 wiring loom (I seem to remember the clocks have difference connectors from last time I checked at the scrappy..)
- Sponsor
yeh i got it out (just), twas a bit of a battle but got there in the end. i know what you mean with the stalks but there more bendy then they look, lol. plugged the mk3 clocks in to the mk3 and the plugs for the wires are different. ill get a pic tomorrow an show what i mean. should be ok after a session with the soildering iron and some wire cutters
(he says )
dan mate, under the steering wheel on my mk3 theres a cubby hole to the right and i swear thats got a bar that goes across the bottom of the dash and attaches to the other side where the heater controls are.
admitidly i only looked when i was loosening it and trying to pull it out. havent looked since cuz im still trying to scrounge a 23mm socket...
(he says )
- Sponsor
