RCL red to pump red with white strip.
RCL black to pump brown.
RCL white to pump white with green stripe.
RCL white with black stripe to pump white with yellow stripe.
RCL yellow and yellow with black stripe to pump red. Both to the same wire.
So i am left on RCL with brown that splits in two, but i figure thosw will be for lights. Pink one, red with black stripe and two orange, one orange is with black stirpe.
On a pump i am left with extra red and white, brown, yellow with stripe and black one.
Also i didnt use the small six pin connectors. What are they for?
I would check the wire splices on the white and white/black wires have properly connected, as if not firmly pressed into place, sometimes they dont make a good connection
I assume you have tried unlocking the car then pressing unlock on the key to see if it locks (to test for circuitry being wrong)
The spare wires I cant say what they are for - did you get a wiring diagram with the kit? If you could post a pic up of it, that'd be helpful.
Also, the small six pin connectors - they are probably for jumpers to configure the kit for other things. I think the kit boxes have changed a little over time.
Yea i tried, locking with key and then unlocking with the remote and vice versa but no luck. Also i connected to brown wire to a signal and the light is working. It's flashing when i lock/unlock with the remote, but still doors won't unlock/lock.
