6N - Passat W8 Domelight mod
Speedlaw
Moderator
Post by Speedlaw »
Yup, that's Perl Grau (Pearl Grey), which suited my Mk4 interior well. Are the Mk5 bits more cream coloured?
The roofliner only needed like half a centimeter cutting, the new frame dictates the size you'll need. Obviously, the inside of the new tin frame needs to be cleared. Better take out small bits at a time, can't really hit the Undo button on this one...
Josh_PoloGTi
Drives: BMW E85 Z4 3.0i
Post by Josh_PoloGTi »
Yeah, lol at the undo comment!
I'll take it slow, and only cut a little bit at a time... Now where did I put that knife?!
J-O
Post by J-O »
so Josh, have you finished installing the Domelight?
was it difficult and what's the result?
Josh_PoloGTi
Hi J-O
The actual light bit is still in Germany :(
Don't worry, I will update this post when I get it installed!
polo2k
Post by polo2k »
right well then i had a bash at this mod tonight and id firstly like to say that its NOT easy, there is a lot of fiddly bits and pieces and a lot of swearing.
rather than give everyone paragraph after paragraph of text to read ill show you the pics (please bear in mind that these are not the finished article but it got to midnigght and was 3 degrees so i called it a night)
ok well before you start you need a feed for the leds and illuminated buttons, on the 6n2 remove the light swich and tap into the blue and grey wire, then run it up the a pillar and to the dome light (this is the correct wire if you wist to tap into the dimmable circuit)
here is the stock 6n2 item
here is a slightly clearer version of the way the wires plug into the light
-left-white-new-illumination
then brown and white-door signal wire
then brown -earth
then red-live
you can see the size difference here
here i have marked what needs cutting, you also need to remove a lot of the black foam above the head liner
some illumination pics with just the buttions and leds lit
here the (uk) passenger map light is on
both map lights
the works
here is the dreaded gap but please ber in mind im not finifhed so this may be gone soon :wink:
and this is a photo i took of a piece of white paper under the leds to show the degree of illumination
ok please forgive the bad photos but i may be working on this tomorrow as well so there might be some more :d
Josh_PoloGTi
Here's mine...
I've just completed the install:
Nice, Very Nice!
Speedlaw
Moderator
Post by Speedlaw »
Looking good guys.
It seems that the gap varies depending on the angle it's viewed.
8)
polo2k
Post by polo2k »
very nice josh and i think ill try the "secret"
J-O
Post by J-O »
yes great work guys.....you're giving me confidence to try it now :D
Polo17
Post by Polo17 »
looks sweet! i want one! :lol:
J-O
Post by J-O »
I finally ordered mine today...I'll try to fix it Saturday as well as the one of my friend in his Golf IV 8)
J-O
Post by J-O »
Well this morning I've fitted my W8 Domelight...
I have a sunroof so it's not the same as yours...I have a plastic panel that needed to be cut....I've cutted 2 of the fixing clips...
once the light was fixed to the panel, I've change the plug to fit the new domelight plug...and now everything is fine...I onle have the same gap as polo2k but I don't mind :roll:
I've change the 2 red leds with blue ones 8) and the four lights were converted to 4 blues high intensity leds :D ....the illumination with the door is connected to a system design by a friend (www.madis.ch) to ligth the leds softly and to turn them of softly after 3 seconds...that's pretty cool :-D
I still have 16 leds to place under the dash and on my ice instal... :wink:
J-O
Post by J-O »
Finally, here's what it looks like at night:
the light that is connected with the doors:
a view of the W8 domelight with the red indicators and the 2 blues leds plug onto the headlight command:
and here a overall look of the counter and other devices....
note that the middle part is painted in Blue RS...so that's why it is so blue on the picture...it's not only because of the leds :wink:
Josh_PoloGTi
Nice one mate... Looking Good!
Are you happy with it?
J-O
Post by J-O »
yeah I love it :P
probably next week I'll plug the others Leds....blue everywhere :twisted: :twisted:
