9n3 gti rear valance
Request Polo related stuff! - Threads Automatically Deleted if no reply within 28 days. BUMP once every 14 days if necessary.
Kuru14
Post by Kuru14 »
Looking for a rear valance from a polo gti ,9n3. Anyone got one or know where i can get one from?
Would dealers be the best option and if so anyone know how much or a part number?
RITCHAT
Re: 9n3 gti rear valance
Post by RITCHAT »
Kuru14 wrote:Looking for a rear valance from a polo gti ,9n3. Anyone got one or know where i can get one from?
Hi
Part number is as follows and are readily available at £35.22+ vat @ 15% less any discount you can negotiate.
V6Q6 807 521 A9 B9
You will need 1* tx30 screwdriver ,1* a flat blade screw driver and a rubber mallet and a cloth to protect your own bumper. Takes about 15 minutes to fit no need to remove bumper can be done whilst on the car. Theres is three screws to be removed for the valance and possibily 5 tx 20 screws if you have mud flaps fitted on the rear each side to remove so another screwdriver required. Give the mud flaps a good wash before refitting as will be full of mud etc. The mud flaps will fit back on no problem just one 2mm hole each side required to be drilled and you will be back to normal again.
