not in good shape at all
FK Highsports Coilovers (3 years later)
- revolutionrock
Re: FK Highsports Coilovers (3 years later)
Citric acid and water will do a good job!
- ticki
- Sponsor
Oh and it gets better on the other side
FAIL
FAIL
FAIL
begining to see a pattern here
FAIL
https://www.youtube*.com/watch?v=T1fysqpNb7k
FAIL
FAIL
FAIL
FAIL
- Tim_GTi
- Post Whore
Ohhh not good! Mine look pretty minging, not that bad though.
- ticki
- Sponsor
did you notice the plastic casing on the coil springs are flaking off.
2 of the dampers are leaking. the rear one is completely blown now.
- Tim_GTi
- Post Whore
yeh, mine are flaking the same, nightmare.
whats the warranty on FKs?
my mates blew the otherday, luckily i had a spare rear set to replace it.
my car failed its 1st mot cos the front drivers was burst the coilovers cant b more than 3 years old. is there anywhere that will fix them or is it better just 2 get new 1's?
- Tim_GTi
- Post Whore
pretty sure they can be regassed if they're not totally ruined. but then you've got the issue of the adjustors probably seized. so i would just go ahead and get a new set, or persuade the company you bought them from to provide you with a new one!
