rear disk conversin 9n3
i have a 06 reg 9n3 1.4 petrol. is it a big job to convert the rear drums to disks?? any input would be greatly appriciated.
Re: rear disk conversin 9n3
A doddle to do if you can get a donor car like I did other than that it will cost a few bob and time sourcing the parts from the stealers.
I t is a straight swap of the rear suspension if you can get a donor car and the brake pipes are easy to do only hassell is the brake cables but again easy to do I used some wire to pull through so I could get the hand brake to accept the new cables. Very straight forward. The abs sensors are the same for the discs as they are on the drums so don't buy new ones as waste of money just be careful taking them out as break easily.
