Polo 9N camber?
hartge
Polo 9N camber?
Post by hartge »
Hi guys,
Car failed MOT as the tyre wear on the inside of the front wheels was near minimum level!
Can the camber be adjusted on these cars? the garage told me it couldnt be done?
any help would be great
gavs
Re: Polo 9N camber?
Post by gavs »
The garage is correct. Like the mk4 Golf (on which the 9N is based, and 6R for that matter) the only way to adjust camber is both wheels at once to try and achieve a balance from moving the subframe side to side.
I'd say it's more likely a toe-in issue with your tie-rods.
