6n2 spacer help
jackwoodman10
6n2 spacer help
Post by jackwoodman10 »
I have a 6n2 lowered on ta technics with standard normal alloys, I want to widern my wheels and fancy using these,
http://www.larkspeed.com/index.pl?a=i&k ... 1S90108003
Will they fit a 6n2? 4 stud and if so does anyone use them and are they worth it?
Any pictures of people using them please post!
Cheers jack
Monkey-Man
Re: 6n2 spacer help
Post by Monkey-Man »
Wouldnt bother matey, personally id save a little more money and buy hub centric spacers. Far safer. With these aswel, didnt read if they are supplied with the spacers themselves, but your also going to need wheel bolts which are 8mm longer. If this isnt included in the kit then your going to have to factor sourcing and paying for those ontop of the spacers and by the time you would have done that you might aswell have bought som hub centric ones.
You can pick up 4 hub centric spacers cheap enough on ebay matey and you could go up to 10mm on the fron and 15mm on the rear with the standard 185 55 14 tyres on standard 6n2 alloys
