Just fitted 35mm H&R springs onto my 9n3, and the back seems to be sitting a tiny bit higher than the fronts. I was looking around for a way to get the back a bit lower and have come across a few people saying to cut the rear bump stops. Is this a wise idea? How will it affect the car? And how much to trim off the bump stop?
Instead of cutting them could I just but some shorter ones? I've heard Powerflex do some, can anyone provide any links?
Rear Bump Stops
Re: Rear Bump Stops
Jacked her up to have a look today and realised I had no idea of what I was doing.
I figured that this dirty orange thing was the bump stop:
But it seems to be attached to the plastic tube below it, so before I started butchering anything I was wondering if I was even doing the right thing??
Apologies for my complete noobness.
- joe2612
- Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
Re: Rear Bump Stops
Noooo don't touch that. It won't affect your ride height at all. What i think you referred to in your original post is people cutting thier topmount rubbers down (sits at the top of the shock between car body.
Re: Rear Bump Stops
Good thing I haven't done anything then!joe2612 wrote:Noooo don't touch that. It won't affect your ride height at all. What i think you referred to in your original post is people cutting thier topmount rubbers down (sits at the top of the shock between car body.
The rear sits a good inch higher and its bloody annoying.
Re: Re: Rear Bump Stops
If it makes you feel better the front sits higher than the rear on mine hahaLucaio wrote:Good thing I haven't done anything then!joe2612 wrote:Noooo don't touch that. It won't affect your ride height at all. What i think you referred to in your original post is people cutting thier topmount rubbers down (sits at the top of the shock between car body.
Sent from my GT-I9100P using Tapatalk 2
