will these fit 312mm brakes
M15RPD84
Post by M15RPD84 »
Ive located a set of 312mm calipers n carriers of a 99 s3 will these fit on my 9n polo gt using original brake hoses n just simple bolt on? Thanks
Tony Boi 92
Re: will these fit 312mm brakes
Post by Tony Boi 92 »
bump
M15RPD84
Post by M15RPD84 »
Why have u bumped my question?
Eddie9n
Post by Eddie9n »
Yes these will bolt on using the original brake lines absolutely fine. The hubs are the same on the gt and gtis so the upgrade is bolt on :).
M15RPD84
Post by M15RPD84 »
Rub em down slap em on cant wait thank you.
M15RPD84
Post by M15RPD84 »
Will these go behind 16" steels (winters) 16" fabia vrs wheels?
Eddie9n
Post by Eddie9n »
Yes they'll go behind 16" wheels fine. I've got 16" winter wheels too and they look quite impressive as there's only a few mil clearance. Hope you get them sorted alright!
M15RPD84
Post by M15RPD84 »
Yer braided hoses on route hoping to get em on at weekend. They look massive off car lol. What difference did u notice?
Eddie9n
Post by Eddie9n »
You don't need braided hoses but they'll certainly help. I noticed a massive difference after fitting mine but that was partially due to the pads on the old set up being worn down to metal! To get the best out of the bigger brakes, team them with oem discs and Ferodo DS2500, you'll be on to a winner then! What colour did you decide to paint them?
M15RPD84
Post by M15RPD84 »
Thats the tough question I dont know yet urs?
Eddie9n
Post by Eddie9n »
I wasn't sure what to do mine either so I just did them black. I think it's a little boring now!
M15RPD84
Post by M15RPD84 »
Im wrapping whole car in apple green so I think green is the way !!
Tony Boi 92
Eddie9n wrote:Yes these will bolt on using the original brake lines absolutely fine. The hubs are the same on the gt and gtis so the upgrade is bolt on :).
do all 312mm's fit onto the 9n3??
Eddie9n
Post by Eddie9n »
Tony Boi 92 wrote: do all 312mm's fit onto the 9n3??
It depends which 9n3 you have. If you have any other bar the gti and the pd130 you'll need new hubs which can add to costs. It also questions whether you actually require the extra stopping power and whether it will be utilised - track days etc.
Most 312mm's fit but make sure that they're off a car which is 5x100 - the Octavia vrs mk1, audi tt (pre 2006), seat leon cupra etc.
Hope this helps!
Tony Boi 92
Hope this helps!
Hi Eddie
i have the gti 1.8t lol, 9n3
i want a good stopping power, i need up an upgrade from these standard gtis lol
so as long as its 5x100 im good?
im considering porsche 996/boxster or just dub 312mm
what ya recon
