breathing
breathing
Okay whats the best airfilter for a mk4 polo?
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
- Moderator
- Josh_PoloGTi
Hi Nelson
If you go for a panel filter (ie. K&N Filtercharger), it lets your engine breath more easilly (like sucking a Tunes!)
They claim a slight increase in BHP, but mainly it helps to get rid of flat spots etc.
With an Induction Kit (ie. K&N 57i) as long as you've got a good cold air feed from the front of the car to the filter you can get a few more BHP and it makes a loud sucking noise on acceleration.
Most people nowadays are going back to panel filters unless the design of the engine allows you to mount an Induction Kit near the front of the engine bay next to some cold air.
On the Polo, the mounting position is at the top of the engine right at the back... Hottest place in the engine bay, so they're not particularly effective.
Hope this helps!
Hope this helps!
- Moderator
Does a Panel filter (or drop in filter) actually help? I'm taking my car in for a service pretty soon and that could be the right time to consider upgrading the standard panelfilter to a nice K&N item.
I'm not expecting any substantial power gains but a better (smoother) delivery would be much appreciated. Should I start looking?
- Moderator
i think the rule is somthing like this:
if a part will not be replaced free by the dealer (i.e. filters when you get a service) then it is your choise of what to put in there
example: your tyres wear out and instead of putting continentrals on again you opt for some michlins or dunlop etc then as long as they are the same size then they dont invalidate the warrenty do they? if however you swap your 13" steelies for 19" alloys then the warenty is invalidated as other parts may be affected however some items may not be invalidated, example: if you change your head unit then it is not vw garanteed but the engine will still be. the whole waranty thing is a bit of a gray area and the dealers WILL choose their own threash hold point
One Time i tried to put one conic filter but I get scared coz it start like shake or tremble the accelerator and brake pedal
WHY don`t ask me. So I just put again de pannel.
What I did las weekend and it help allot is to take out the first inlet tube or piece of box that is on the filter box. Instead I put a direct tube to the front grill And it felt a better response
