hi I'm new on the forum and it would b a massive help if any1 has come across this before
my car is vibrating wen i pass 4000 rpm it dose this in all gears and neutral but is more noticeable in 2nd altho the vibrating defers in pitch as i go up the gears it gets deeper in pitch
story behind it is i have recently had a new gearbox and it was whinny so i took it back and the whinning had gone but the vibrations was still there ruling out the gearbox
thanks for any help
mike
vibration past 4000rpm
- bstardchild
- Moderator
Re: vibration past 4000rpm
Engine mounts?
Exhaust dropped and sitting on the chassis link mounts?
I agree you can rule out drivetrain as it's rpm dependant in all gears
