Exhaust System Warning Lamp, BACK AGAIN!
Discuss Engine, Gearbox and Exhaust
JangoJamie
Post by JangoJamie »
Hey guys, long time since I've posted on here..
Just this morning I was casually driving when this f*****g dick of a warning light popped up!
Couldn't really believe it if I'm honest. Since the first time the warning light came up like last year I have had
- The catalyic convertor changed
- The front lambda sensor changed 3 TIMES!
- A brand new exhaust system (Literally a week ago I got a new silencer for my M.O.T.)
I really need a new car!
Anyone else had this problem constantly since they got their Polo?
Jamie
emma_88
Drives: 6N2 Polo GTi & 9N3 Polo GTi
Re: Exhaust System Warning Lamp, BACK AGAIN!
Post by emma_88 »
Have you not got access to vagcom? As it could be a range of things.
JangoJamie
emma_88 wrote:Have you not got access to vagcom? As it could be a range of things.
Like what? No I havent got access to vag
fonzooorooo
Post by fonzooorooo »
The handbook refers to this as exhaust system warning, but it shows any engine management issue - throttle body, temp sender, lambda, cam/crank position sender, coil pack... really - everything!
You can get a OBD scanner for £15 off ebay. (I recently did this - surprisingly useful!) That's less than most garages charge for plugging it in once. The cheap ones have a book with codes in. They're not all in the book(!) but a quick google usually provides!
benmkiv
Post by benmkiv »
Any of these odbii readers are a worthy investment. They show you all the code numbers and a simple google on Ross tech wiki will tell you what's wrong and possible solutions. So worth the money! :) as said above can be any number of engine codes just some silly little thing.
