Stone Chip Repair! lots of pics!
Detailing & Bodywork
dino
Sponsor
Post by dino »
bombertdi wrote:
dino wrote:i added a little paint on the scratch before sanding.
With Scratch-X you would be there hours trying to remove sanding marks tbh.
Any suggestions on the best product for removing sanding marks by hand ??
TBH im not sure and dont want to suggest a product that may not work in removing the sanding marks. I personally would try it without a Porter Cable.
M7 wrote:i think i need to do that...one day i'l grow the balls to do it! :lol:
top results though
Cheers Ryan.
JPR_polo_gti
Post by JPR_polo_gti »
awesome job, someone should pin this
sapphireflame
Post by sapphireflame »
very brave!
if i were to do that to my car the entire car would have to be done its so full of chips and scratches (i was very friendly with bushes on country lanes when learning!)
chrisash32
Post by chrisash32 »
sapphireflame wrote:(i was very friendly with bushes on country lanes when learning!)
Upgraded to car park bollards once you had passed
sapphireflame
that was only because i was too busy looking behind me and forgot to watch teh front end!
i'm getting some paint and sorting out teh major ones soon
tompolo
Re: Stone Chip Repair! lots of pics!
Post by tompolo »
trying to bring this post back to life here!!
I had seen these pictures a while back and figured i'd give it a lash
I have bought a paint touch-up kit containing a paint-match, laquer, and polishing compound.
I was planning to over-fill the chips and a few scratches with the paint, then sand even with 3000 grit wet sand-paper(is this just wet with water?), then polish, clean, apply lacquer, sand, and polish.
I haven't got an electric polisher, but was planning to use good irish elbow grease, but have now found out that a polisher might be required...
1) Can this all be done by hand?
2) What can be used to remove sanding marks(3000grit-wet)?
3) I have already applied the paint, so no going back now!!!
4) Yes, i'm a fool but i'm gonna try diggin upwards for a while!
5) Is it good, or a waste of time to try polishing out sanding marks before applying the lacquer? or would the lacquer hide the marks?
6) I havent sanded anything yet, i have yet to make that mistake!
any help appreciated,
tomas
Tim_GTi
Post Whore
Post by Tim_GTi »
Short answer, not easily. You'd need a machine polisher to get rid of the sand marks!
Although if you got a fairly abrasive polish (meant for a machine) and really went at it, it may work
alanjwong
Drives: 2001 VW Polo 6N2 1.4 16v 100BHP
Post by alanjwong »
Them results look good.
Did you just use one touchup pen and then wetsand??
What kind of polisher did you use, was it a rotary or a dual action one?? and what kind of pad did you use??
What kind of wetsand paper did you use??
I have a black metallic paint on mine and was thinking of doing what you have done.
Tim_GTi
Post Whore
Post by Tim_GTi »
All the info's there mate.
He used P2000 grit wet and dry paper
A Porter Cable poilisher (Dual Action)
Light cut 4" pad with a medium Mezerna polish
Then a finishing pad with finishing Mezerna polish after
