My routine
- Tim_GTi
- Post Whore
My routine
Thought I might share this routine with you all. It's not instructional at all, merely sharing what I do and how I do it with you. I know everyone does it differently. I just know that a guide like this would have really helped me get off my feet back in the beginning, without having to trawl through endless threads on unfamiliar forums.
First of all a big thanks to Ollie_R who has recommended me most of the products I now use. thanks for the pointers also Jeff.
Ok first thing to do is windows and wipers up. I start with a jet wash. If you haven't got one I'd consider investing, for they play a big part in preventing swirls. Make sure the nozzle is set to wide n spread out, not thin and pointy. And skim the whole car with it, never squirting the paint direct on. This will loosen up and get rid of alot of the dirt and dust you'd otherwise move about and rub into your paintwork whilst washing.
Washing
Once jetted, I use one of these:
http://www.cleanyourcar.co.uk/washing-a ... d_335.html
I put AG shampoo in this at the moment, may be an idea to include a bit of AG intense tar remover in it too. This coats the car with shampoo, and will help dis-lodge anything stubborn.
Let that soak whilst you fill your buckets. ALWAYS use two buckets, fill up one with shampoo, the other with warm water. At the moment I'm using AG shampoo and conditioner, I'll probably move onto to something in the Mer's range once it's all used up though.
For buckets see here:
http://www.elitecarcare.co.uk/product_i ... 49044eef72
These have grit guards also, so will stop anything that comes off your paintwork going back on when you swirl out your mitt!
Once your buckets are filled your ready to go.
I use a sheep wool mitt to wash my paintwork, they are brilliant!! Something like this:
Use the shampoo filled bucket to soak your mitt; this is your washing bucket. When you've finished washing a panel, rinse off your mitt in the water filled bucket to remove dirt. Then soak it again in your washing bucket. Repeat this process for the whole car; wash with one bucket, rinse with the other. This is the two bucket method, it's prevents old grit and dirt getting back onto the paintwork and scratching it.
When washing, wash in straight and circular motions, starting from the top and working down (cleanest, to the dirtyest). I do the following:
wash roof
wash bonnet
wash windscreen
wash all side windows
Change the water in both buckets, and give the car a quick soak with the jet wash (to prevent watermarks). Then:
wash the top sections of all doors
wash the front quarters
wash the rear quarters
wash the rear windscreen
Change bucket water, and give the car a quick jet wash. Then:
wash the lower sections of all doors
wash the tailgate and rear bumper
wash the front bumper
Then a final soak with the jet wash to get rid of any left over shampoo.
It's now clean! You need to dry it as soon as possible.
I use these:
They hold water really well, and don't leave smears.
I drag one of these over the whole car really quickly, spreading it out as much as it goes, eliminating all resting water. I then take another towel (i have two identical ones) and perfect each panel, buffing dry. I open and slam all doors to get any future drips out and dry them.
your car should now be perfectly dry and clean.
Claying
Claying your car gets rid of contaminants on the paintwork, that aren'y picked up by the wash, and can't always be seen by the eye.
It works by spraying the area you wish to work with a lubricant, kneeding the cay so that it is soft and managable, and gently gliding it over the lubricated surface. NEVER run clay over a dry surface, and wipe area dry once finished.
Here's the clay kit I use:
It's nothing special, probably gunna try some of this next:
I don't use quick detailer for lubricant, it's a waste of product. Instead I just use standard water in a trigger spray bottle.
Spray water onto the paintwork, shape the clay into a large flat shape and very gently glide it over the surface. Wipe dry with a MF cloth like these:
Here's a good video to claying, I havent gone into it in massive detail so this may help:
http://youtube.com/watch?v=ZcZRj509Ir8
Polishing
I use this stuff:
It's fantastic, gives a nice deep shine and is easy to buff off.
I apply is using these:
Very handy little things.
Squirt a blob about the size of a two pence piece onto the MF applicator and apply it to the paintwork in circular motions. Just so you have an idea 2-3 blobs (alot of people will even use less) will cover the bonnet.
Apply this to the whole car first, this gives the polish time to cure.
Then once finished, buff off with a the same circular motion using a MF cloth. or something like this:
I polish, once every 1-2 months approximately, depending on upcoming shows/meets etc.
Glazing
New to this stuff, and it's great.
It's something you throw on your paintwork inbetween polishing and waxing to get a real deep shine out of the paintwork. You buff on and off as you would a polish. Use an applicator pad of MF cloth/block to apply, whatever you feel more comfortable with, and MF cloth/towel to buff off.
This stuff is amazing:
http://www.elitecarcare.co.uk/product_i ... cts_id=435
Only tried and tested on my bonnet at present, because of the poor weather. But it really is great, very easy to apply and buff off.
Waxing
I use Collinite 476s:
I've used a few waxes, and this is by far the best stuff I've used. It's my favourite product I have. If your using megs step3 and think that's good, you'll laugh once you've tried out this.
Use an applicator pad to apply, and MF cloth to buff off. Just like what's included in the kit in that link.
Again apply sparingly, 1 dab of the tin should cover the bonnet. And cover the whole car before buffing off, allowing it to glaze over and cure.
Look at waxing quarterly, the coat will last ages.
If you ever find wax or polish like this hard to buff off, a suqirt of water msited over it before buffing off will help alot.
This stuff is really good to use before applying a new coat of wax:
http://www.vertar.com/car-care-exterior ... eaner-wax/
It strips the car of any wax/polish on the car. So it's good to use this first just like you would any other polish (MF applicator and MF cloth). Then repolish and wax after!
Wheels
I tend to do this first because it's my least favourite part!!
Use a different mitt to the one you use on the paintwork. I'm currently using a MF one, but a woolen one will do a great job also (probably better actually).
I give each wheel a quick squirt with AG custom wheel cleaner, then use AG shampoo just like the paintwork, again using the two bucket method. I also have a softbrush toothbrush at hand, for the tight spots!
Before drying the wheels I give them a quick quirt with AG Aqua wax,
http://www.elitecarcare.co.uk/product_i ... cts_id=286
I've had this stuff for ages, it's useless on paintwork but I knew having it lying around would come in handy for something at some point. It's good for bringing out a quick shine, and adds some protection between washes.
After letting the aqua wax set for a while, I dry and wipe them down with a MF cloth.
I'm currently using the collinite as my main wheel sealant, it offers great protection, but when I make another order from eltecarecare I'll probably get some of this:
Recommended by Ollie. this would last as long as wax on paintwork.
A great product for tyres, again recommended by Ollie, is this stuff:
http://www.armorall.eu/uk/wheeltire2.html
Comes ready with an applicator. I've tried stuff from megs turtle wax etc, but they're not that great really.
For plastic trim get this stuff:
A simple wipe on, let cure and wipe off method is all you need. Great stuff.
For rubber seals, apparently 1z Gummi Pflege is ment to be the daddy. Haven't had a chance to get hold of some at the moment though!
Windows
to be honest, the best smer free stuff I found for this was water in a spray bottle. I used to only use it on my rear tinted windows for film protection reasons, but found it works great on both inside and outside.
After initially washing them like the paintwork, spray them with some water and wipe them dry with a MF cloth to eliminate watermarks.
If your windows are shoddy however, or they fail to gleam, use this stuff. It's great:
http://www.elitecarcare.co.uk/product_i ... ucts_id=97
Apply like a normal polish.
Interior
A quick dust and a hoover is a good start.
I then run over all the plastic dash, doorcards etc with this, can't fault it:
http://www.elitecarcare.co.uk/product_i ... cts_id=107
Don't get it anywhere near your seats though, it's a right pain to remove.
Generally, a good method for cleaning seats is good old water and a brush. Products like AG Hi foam shampoo (link below) are good to use, but you have to apply it to the whole seat because it stains when drying.
http://www.4wheelplay.co.uk/autoglym-hi ... 00130.html
for interior windows, see previous 'windows' section.
That's pretty much it I think, next for me is a foam gun and DA machine polisher
Hope this helps someone, any questions feel free
Washing
wash roof
wash bonnet
wash windscreen
I use these:
Claying
Polishing
I use this stuff:
Glazing
Waxing
Wheels
Windows
Interior
Nice guide Tim..I use slightly diff products, but will have a look at those, still trying to find the best ones, also try some Mr sheen or other silicon based spray on a rag for your door rubbers
Had a look on a detailing forum a few nights back and they scared me, when they got out the paint thickness electronic gauge, I thought mmm time to leave. To each there own I suppose, good site if a little bit OTT
i've got it down to a fine art to remove the kebabs the muppets leave on my car now.
