Hey just a quick question. Have been real lazy recently and cleaned the car once in about 2 months
So to prepare for winter what is the best wax to use, and is there anything else i should be doing?
Also my wheels are disgraceful,so they could do with a proper clean, anyone used anything to really get off ground in crap?
Cheers.
Best wax to use for winter?
- Drives: Polo 1.9 Tdi Sport
Cheers , thats awesome!! will have a look around for some for prices and availability! Need the good ish weather to last just till next week now!!
Also quick question not sure where this should be tho.
What paint/primer should be used on an engine cover, plastic abs i think it is.
Had some paint on a while back. Now its flaking off as its crap. So am sanding it down but need to really repaint it.
Got me a new smart looking oil filler cap too. The audi R8 one! Just need to clean the engine, get the cover painted and then can show some pics!
Haha ive sprayed most of my engine matte black and I have the R8 cap as wellpolo1.9TDI SPORT wrote:Cheers , thats awesome!! will have a look around for some for prices and availability! Need the good ish weather to last just till next week now!!
You can get heat resistant primer, but most thermal paints do not require primer use, they are straight on, leave to dry 15-30min, place carefully into the car, run the car till engine heats up. Turn off car and leave overnight as the paint needs heat applied. Otherwise it cracks like the sand on a desert and looks crappy. If you plan on doing plastic, sand them down and then paint, same for metal as well really (as this will insure a far smoother and cleaner surface).
I have used hycote paint plenty of times now and its brilliant as a thermal paint.
Can get it in some local motor spares shops, but loads of the stuff on ebay for a few quid. Think its zombiecars that sell it... here's a link:Tim_GTi wrote:So for a plastic engine cover you'd recommend getting hold of some 'hycote' paint (where would I find this?) give it a quick sand, paint it on, run the engine up to heat then take it off and let it harden over night?
http://cgi.ebay.co.uk/HYCOTE-VHT-HEAT-R ... 286.c0.m14
You basically got the details rights,
1) Take of part that you will be spraying
2) Sand/smooth down the part
3) Paint, several coats and allow the coats to dry (but not fully which is 15-30min), basically you don't want the paint looking wet but instead it looking dry
4) put item carefully back into the car, trying not to catch any paint work
5) Run engine till it reaches normal running temperature (90c I think)
6) Except that after running the engine you can leave the item on, this is because as the engine cools there's still allot of heat in the bay which is an ideal environment for the paint to dry and get use to the temperatures (especially for thermal paint as in workshops its baked).
If the paint is to wet and you didn't let it settle down for 15-30min so it looks dry it will crack after being exposed to heat and then cooling, which is why you need it to dry abit before shoving it back into the engine bay, the engine bay is really ideal as the temperatures also drop slowly inside after which is extremely ideal for baking thermal paint, hope this helps.
Cool , will have to have a look at this then! I have heard that you can use normal car spray paints too due to the engine not being "that" hot. Dont know what to do. Like the idea of candy red or something but they are not available in high temp paint.
By the way
Will be gettin the wax kit with applicators!!
Best to really!
By the way
Best to really!
If you got a local paint dealer then you might be able to get custom mixed temp paints, problem with that is you need a compressor to be able to spray mixed paints.polo1.9TDI SPORT wrote:Cool , will have to have a look at this then! I have heard that you can use normal car spray paints too due to the engine not being "that" hot. Dont know what to do. Like the idea of candy red or something but they are not available in high temp paint.
