[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Big Turbo GTI build Redine mag front cover DYNO VID - UK-POLOS.NET - THE VW Polo Forum
i need these bushes badly, when i was trying some other wheels yesterday, when i was tightening my wheel nuts, with the wheel on the floor, the wheel moves really bad front to back! Because of that bush
You're a star, thanks for your reply. Another question for you, to do a 312mm brake upgrade, what exactly is needed apart from discs/pads?
White do you have a part number for the top mount you're replacing? Can it be done without taking the strut completely out (without disconnection the driveshaft), i think mine is definately knackered.
flyfs6 wrote:You're a star, thanks for your reply. Another question for you, to do a 312mm brake upgrade, what exactly is needed apart from discs/pads?
brake calipers and the carriers nothing else
i have some 334mm setup off the r32 ready to fit just need some bigger wheels now
Ring Vag parts they sell them £7+Vat and yes its just the bearing part of the top mount and you need to remove the strut complete , dont remove the drive shaft, just undo the bottom ball joint off the arm (3 Bolts) and its then it drops clear!
whitegtipolo wrote:i need these bushes badly, when i was trying some other wheels yesterday, when i was tightening my wheel nuts, with the wheel on the floor, the wheel moves really bad front to back! Because of that bush
is that the front wheel? I always wondered why mine rocked so much, thought it might be loose....
