Hi guys
I have a water leak in my polo giving a lot of trouble.
First became apparent wet foot well wells, I saw water leaking from rear door seal and traced it back to a dripping connector in roof.
It looks like the sun roof drains both front and back is a problem, I can see water running down from behind the dash board into the drivers foot well, and i can see the pipe when i removed the tweeter trim, but the end is out of site and i cant get to it.
I can see a relay panel behind the dash also a connector panel which i have been trying to remove, in order to see the end of the drain pipe and maybe fix it.
Removing the dash looks maybe a bit much for my senior years.
Pictures that i have seen shows drainage from the front door column in my car there is a solid rubber grommet where that use to be the case.
So i imagine it now draining (or should) into the area below the windscreen engine area. which has been cleaned out
Any thoughts would be appreciated. its driving me nuts
Thank you.
