Marjacic wrote:Ciclo, could you maybe help me :lol:
i am looking to order the 7E0 bcm soon
with witch pqr number do i have to order when i order it?
polo 6R Tdi 105 hk 2011 :)
VERY IMPORTANT JUST BEFORE YOU MAKE THE CHANGE OF BCM
With previous BCM installed:
- VCDS log: autoscan.
- VCDS logs: .csv files of adapmap BCM (address 09) and Gateway (address 19)
You can buy this model:
Image Image
Requirement prior to installation in your 6R (non BlueMotion):
Two wires (0.5mm thickness)
IC T32/28--->BCM T73b/54
IC T32/29--->BCM T73b/57
Image Image
Isolating original wires, T32/28 & T32/29, by separately...Image
Image Image
Replacement: source Ross-Tech
http://wiki.ross-tech.com/wiki/index.ph ... ctory_Mode
http://wiki.ross-tech.com/wiki/index.ph ... Adaptation
Before buying read this: https://www.drive2.ru/l/7318540/
In your Polo without factory xenon and non bluemotion will have the same fault.
ciclo wrote:ah!...this weekend I will correct some of my BCM Bytes (nothing important)
Friday,15,January,2016,21:45:42:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.3.0
Data version: 20151216
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate:
Mileage: 17310km-10755mi   Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 20 25 2E 37 44 55 56 77
VIN: WVWZZZ6RZDY0CICLO   Mileage: 17310km-10755miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 2686
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004004
   ROD: EV_ECM12TFS02103F906070FJ.rod
   VCID: 6A1F7AE4CFD85FA88D-803E
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   VCID: 02B74ABC23A0CF80CD-8056
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38E1E65E1FDE8B0A1D-806C
Address 09: Cent. Elect. (J519)       Labels: None
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 100150209
   Coding: 3CB02FBF08E1240093380E917CEB9FD0DAC0672F600D30D0200000030800
   Shop #: WSC 03607 002 104857
   VCID: 681186EEDFAE6BBA9D-803C
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 110215 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3EEBD2603FFC575CED-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 4AFFBA844F381F888D-801E
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB405N1C4LI7929
   Crash sensor for side airbag; front passenger side:
   Serial number: 3585HRB405B1D5MS8GS2
   Crash sensor for side airbag; rear; driver side:
   Serial number: 3515RRB405B17ABS901.
   Crash sensor for side airbag; rear; passenger side:
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 35E2E0471BA1991F25-8060
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 002200
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   VCID: 2EDBF230FF8CB7CC6D-807A
   Component: IMMO          H05 0607
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2ADFFA24C798DFE88D-807E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 37E0E45D1BDB8D0D15-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V13  8348
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2FD8F4356F83BDC555-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 7720641D131B0DCD15-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3BECDC6903CF6571F5-806E
End-------------------------(Elapsed Time: 03:19)--------------------------
Updated here: viewtopic.php?f=56&t=58703&start=1755#p503577
ciclo wrote: also I will go to test a new, new modification on static cornering lights... :twisted: I expect a good result.
Achieved.
Awesome modification for Polo 6R with static cornering light (in xenon or fogs), WRC, GTI, BlueGT, R-line, etc... and they speed up fastly on traffic circles, roundabouts, tight corners...
New mod
Changing the upper speed threshold for static cornering light.
VCDS
Address 09 Cent Elect, Adaptation, Channel 32, default 40 km/h.
I set the upper speed threshold at 55 km/h.
Impressive performance along with HBA during the test.
Works like a charm.
Remember they are static cornering lights, not dynamic cornering lights. :lol:
Marjacic
Drives: Polo 6R 1,6 TDI 105 hk Highline
Post by Marjacic »
so what you are saying is that it is more difficult and that i will get the fault on light in the instrument? even if i retrofit Xenon :cry: :roll:
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
ciclo wrote:New mod
VCDS
Works like a charm.
I think I'm gonna do this mod aswell. :)
CNK
Drives: 6R
Post by CNK »
ciclo wrote:Before buying read this: https://www.drive2.ru/l/7318540/
Marjacic wrote:so what you are saying is that it is more difficult and that i will get the fault on light in the instrument? even if i retrofit Xenon :cry: :roll:
I have the same question as Marjacic.
What I will should do if I have Polo without factory xenon and non bluemotion?
I would like to change your headlights, but first I have to change the BCM.. :roll: I dream of full LED headlights.. :)
Mart!n-GTI-DK wrote:
ciclo wrote:New mod
VCDS
Works like a charm.
I think you'll like it. However I hope your opinion (very important), please take your time and do the tests with different speeds.
CNK wrote: I have the same question as Marjacic.
The only thing you two have to do is to get all lights are controlled by the BCM. The easiest thing is to have Elsawin and compare your Polo 6R with the electrical system of a Bluemotion (regarding lights). On the other hand if you want to install xenon headlights also have the corresponding section in Elsawin.
Make a tutorial does not make sense, there are many different 6R versions, and the best guide is Elsawin.
Everything is possible, just depends on your ability to manufacture and install the wiring.
I can help, but I can not explain everything from the beginning of creation ... and be answering questions again and again.
You have to have basic electrical knowledge, for example, search on google:
How a switch works?
How a relay works?
How a control unit works?
CNK
Drives: 6R
Post by CNK »
ciclo wrote: Everything is possible
Ok, thx :)
It's nice to read it :mrgreen:
Ok, thx :)
I insist, I'll help, but please open a new topic or a personal topic.
Image...Image...Image...Image...Image...x1.000.000
You two must understand that my last mod about static cornering lights, a world novelty for Polo 6R, will be forgotten forever if it's buried in my topic with your questions.
Maybe you can tell us more about your mod :-) Is it only changing the threshold or more?
good balance between small and big mods :-)
i've given up for now on the discover media from 6C in 6R. becoming too expensive and not sure about succes chances.
maybe I'll continue later. maybe with the 6C configuration or with the T6 version. at least I have OEM DAB reception now :-) but no RNS with DAB LOL
iichel wrote:Maybe you can tell us more about your mod :-) Is it only changing the threshold or more?
Yes, only modify the upper threshold.
For example, it is very useful to see better how you crash when you do drifting ...
:mrgreen:
yes always important to keep a good aim when you crash. :mrgreen:
(I actually LOLed pretty hard on your phrasing :mrgreen: :mrgreen: )
Mart!n-GTI-DK
ciclo wrote:For example, it is very useful to see better how you crash when you do drifting ...
LOL :lol:
This is as good as when Top Gear explains the difference between Over- and Understeer. :lol:
iichel wrote:yes always important to keep a good aim when you crash. :mrgreen:
You know I'm stupid ... in addition as my English is very bad I am stupid man doubly :lol: :lol: ... my only intention is to have a good time after we have a day of exhausting work.
I apologize to everyone, especially to English people. Thanks for putting up with my stupid things, you guys are the best.
Mart!n-GTI-DK wrote:This is as good as when Top Gear explains the difference between Over- and Understeer. :lol:
LOL!... I'd like be so good at explaining things like Top Gear. :wink:
I love Top Gear ... and many other TV programs and documentaries of English people, I'll never have enough words to thank all that I have learned with them. I know, boot licker, ass kisser, brown noser... but it was necessary for me to say this.
some updates (pictures) in this page: viewtopic.php?f=56&t=58703&p=502496#p502496
Ah! I think my new mirror 7E0 is magical :) , I seems that has a sensor inside the glass to change the hue (aspect) depending on the outside brightness, and independent of dimming function. I think it is like the light sensor of instrument cluster and RNS510. I also think it does this via CAN signal... under study...
I don't care how bad your english is. It brings the message, that matters. And it's not that bad, come on man! :mrgreen:
Locked
