Adam87
Drives: T5.2
Post by Adam87 »
I will try tonight [emoji106]
firegrafik wrote:
Adam87 wrote:What is the issue with parking lights?....
I installed Polo 6C LED headlights on my Polo 6R sedan. But my BCM's full number 7E0937090ZHH it has EEPROM preset for Russian Polo 6R sedan with RLS and bixenon.
So in DRL mode the LED-DRL has full brightness (as it should be). But in parking-lights mode it should be dimmed but it gets off at all. I need to find the EEPROM from the T6 BCM first of all.
ciclo wrote: Parking lights 6R: (if Automatic lights)
Signal from T10/3 (light switch connector) -----> to T73a/45
Make a test:
Install a new wire directly from T10/3 to T73a/45. Do not use original wires from factory for Parking lights signal.
Byte18: change the BCM coding if you need. As you know.
In this way should work correctly.
Fernando, wiring is OK for sure.
Everything worked correctly with halogen H7 headlights and halogen DRLs
Perhaps you would have make a test with other LED headlights (or ballast) before make changes in BCM software. :?:
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
iichel wrote:31347 is not working?
In my BCM 7E0 it did not work.
govindsharma wrote:DeAR when i am changing code of j387 to 000002 it there is massage that code rejected out of range and when In my car j386 and j387 only first two character are changing like 100000 220000 any digit but front two or said byte 0 only.
Ok, for that reason there are no labels in the VCDS program. Door units for PQ25 platform remain a great mystery.
Adam87
Drives: T5.2
Post by Adam87 »
No good for me either (7E0 BCM)
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
ciclo wrote:....
Because of amount of difficulties in searching the equipment which could download the right BCM software. Now I am thinking the easiest way is to buy T6 BCM. And do not disturb you, my friends.
Make a test:
By other side:
What happen if you enable Byte 29 Bit5? (just curiosity)
22904AFF48E12400933806017E8B17F00AC073AF60AD30E0200000030820
and with this coding: :?:
22904AFF48E12400933806017E8B17F00AC067AF60AD30E0200000030000
firegrafik wrote:
ciclo wrote:....
If I knew how to extract my BCM software you would already have it, you can be absolutely sure.
Alexander you never disturb, it's quite the opposite. Talking to you is a great pleasure.
firegrafik
ciclo wrote:....
By other side:
Hmm...
OK I will try the Byte 29 Bit5
Byte 28 Bit3 defines that the high/low beams stalk is wired to the BCM. If I make it 0 I will get incorrect working HB/LB
Ok,
Byte29 Bit5 is related with LED headlights modules.
22904AFF48E12400933806017E8B17F00AC067AF60AD30E0200000030800
sorry I make a mistake when copy the coding. :oops:
firegrafik
ciclo wrote: If I knew how to extract my BCM software you would already have it, you can be absolutely sure.
I believe, you would for sure, Fernando.
I talked to professionals in VAG control units. They have original equipment, they wrote VAS 5054 with engineering ODIS could extract the whole firmware and not only EEPROM. But the original VAS5054 with e-ODIS has online connection and it gets security access online. Original VAS5054 is a very expensive. So even I will find Chinese clone VAS5054 which is able to do the same, but without online connection I need to know the security access code. DEAD END.
Much cheaper is to buy T6 BCM, even used one
Skoda Fabia2 1.2 TSI DSG (2011)
Is this the reason for the 106% in WRC? (Display correction of consumptions and operating range,106 %) Image...If so no problem! ... I correct my IC up to get the closest values. :lol:
CNK
Drives: 6R
Post by CNK »
Hey Alexander,
if you want, I can order and send you used BCM from Poland :wink:
Or you can try to send directly, buy as you know, many sellers don't send abroad.
I think that the price can be negotiated BCM to ~500 PLN + shipping costs
http://allegro.pl/vw-t6-sterownik-modul ... 83007.html
http://allegro.pl/vw-transporter-t6-mod ... 26679.html
http://allegro.pl/vw-t6-2015-16-r-modul ... 63858.html
http://allegro.pl/vw-t6-2015-16-r-stero ... 82443.html
http://allegro.pl/vw-t6-16r-sterownik-m ... 00870.html
firegrafik
ciclo wrote:.....
Checked each coding variant. Not helped.
Noticed one interesting thing. When Byte29 Bit5 is 1, with switching low beam or just flashing high beam, there is "yellow bulb" warning light on Instrument cluster appears, but there is no any fault in the 09 centr.electr and in the other control units. :shock:
Locked
