chisyelamos1
Drives: 6c 1.4tdi
Re: RE: Re: ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
Post by chisyelamos1 »
iichel wrote:maybe it's easier if you send us the link to that website instead of making photos of the screen ;)
if it goes onto a footwell light, my first guess would be a 1J0 972 923, the one that ciclo suggested to you
Yes, it is for footwell light or trunk light.
Sorry but i don't find a photo that clearly shows the connector, but I think that is correct number suggested you.
What type of inner connector would have? (Metallic)
Thanks!
Enviado desde mi LG-H815 mediante Tapatalk
you'll need two micro power timers.
i.e. VW repair cable 1,0mm^2: 000 979 133 E (1x cable has two connectors)
Adam87
Drives: T5.2
Post by Adam87 »
ciclo wrote:Image
Thanks. :lol: 1000x
[emoji23][emoji23][emoji23]
chisyelamos1 wrote: Yes, it is for footwell light or trunk light.
Thanks!
Hi chisyelamos1
so...
1
6C (6R) footwell light
2
Connector
3
Contact terminal
4
OEM. 0,5 mm2 wire (60cm) + 2 contact terminals
Adam87 wrote:
ciclo wrote:Image
Thanks. :lol: 1000x
:lol:
iichel explained it perfectly, but as the cycle was the same it was difficult for me to understand that he referred to the beginning of the operation.
Which he had explained previously.
iichel wrote:by the way, i just realized something.
recently i was messing a bit with the adaptation channels of the bcm.
i noticed that the headlight washers now start at the 5th cycle.
before it was at the 1st cycle.
i guess it's somewhere in 27, 28 or between 50 and 60. it just popped into my mind... but cannot test
In short ... sometimes (many times) I say big nonsense. :mrgreen:
ciclos and cycles
:mrgreen:
ORiOn
Drives: Polo BlueGT / Audi S5
ORiOn
Post by ORiOn »
Hey Fernando!
Do you know of anyone that has been able to make the 5C0 035 680 C radio work on the 6R? :D
iichel wrote:ciclos and cycles Image
ORiOn wrote:Hey Fernando!
No. :D
Note:
Anyway, the RNS 510 is perfect for me Image... my phone is still a stick. :lol: (and I hope it will be in this way for twenty more years)
Hmm... Phone like a stick, 6R without Gra_High ... I am and I will be an authentic caveman. :lol:
... bi xenon headlights... :twisted:
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Re: ORiOn
Post by firegrafik »
In Russia there is available to buy Discovery Media headunit MIB PQ with hacked firmware and component protection deactivated so it is possible install it to the PQ25/PQ35/PQ46 vag models including Polo 6R. There are several DM in stock. But It needs the latest gateway and for Polo there is should be 7E0 max BCM.
Unfortunately, for now there are only audio, Navigation , and Bluetooth are available. Other features (Carplay,Mirrorlink, Android connect) are unavailable for now. But guys are working on this issue.
Price is about 50000 rub (about €800)
https://www.drive2.ru/b/465549716948517747/
https://www.drive2.ru/o/b/465672862250828867/
iichel wrote:... bi xenon headlights... :twisted:
Image... :lol:
Re: ORiOn
Great news!
The price is very reasonable. (it's what my RNS510 cost me many years ago)
RLHS :arrow: (found)
e-UP!
Rain Light Humidity Sensor
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.CLB
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 274161206
Coding: 62B82B0000010000210007D42CEB0EF07100726C604325602100000B0910
Shop #: WSC 31414 790 00001
VCID: 2A18C36F45849712C2-807E
Component: RLHS 150916 0 42 0106
Coding: 0228DD
VCDS
Byte8 Bit0 enabled
Byte8 Bit5 enabled
Adam87
Drives: T5.2
Post by Adam87 »
[emoji106] good news, I plan to get the humidity sensor working also, I believe part no 5K7 955 559 B also has it? (I hope so because that's the one I bought [emoji38])
Did you already have it installed?
I'm afraid that those finished in 559 only RLS and those in 547 RLHS
For example, Golf 2013-2018:
I have not tested to install it. Just found on Ross-tech forum (by googling), ETKA, etc...
I think the humidity sensor is intended for BlueMotion vehicles, in order to avoid fogging the windshield when the engine wants to stop (start/stop function). I suppose that RLHS affects the engine operation and air conditioning (climatronic). I do not know if it will have any kind of beneficial effect for non BlueMotion vehicles (if possible to install on them). :?:
I do not know how this sensor works, but I remembered that you asked me about it some time ago. :wink:
Locked
