ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
New Mod
LEDs license plate lights with light beam whiter. OEM
My R-line is with LEDs license plate lights from factory, however I bought these lights for one experiment..., and finally they are installed on my R-line, forever.
The light beam is slightly whiter.
- Drives: Polo 6C
Hi Ciclo,
i have seen your topic about Wiring taillights retrofit 6C to 6R (Plug & Play).
I am interested about the reverse way, i mean: Wiring taillights retrofit 6R to 6C (Plug & Play)
can you please help me to find the correct references of the connectors, contacts and wires positions that i will need in order to build the adapters.
thanks for your help that i will appreciate too much.
Regards.
Regards.
The position of the wires is the same.
You have all the information you need here.
http://www.uk-polos.net/view ... 13#p466570
- Drives: Polo 6r
Buenas ciclo gran trabajo con ese rline. Podrías solucionarme una duda con la adaptación de xenon y lavafaros a un polo normal un saludo
Mart!n-GTI-DK, tell Watcher try this coding. Not sure it will work.
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H01 0102
Coding: A5FFFF
Of course, ask your doubt.Danilugomk5 wrote:Buenas ciclo gran trabajo con ese rline. Podrías solucionarme una duda con la adaptación de xenon y lavafaros a un polo normal un saludo
Claro, dime cual es tu duda.
- Drives: Polo 6R
What you will do with your old steering wheel? I really like the new one...
For now I will not change my steering wheel, the above image is from Watcher.
http://www.uk-polos.net/view ... 34#p473651
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Coding: A5FFFF
Hello again!ciclo wrote: BCM
64B02B3F08A1000021380F916EEB0FD05AC0672F7E053041200000030000
Please tell us the results.
The coding you provided is working fine and everything works the way it should. I made a change though, as I prefer the cornering lights for CH/LH Also for now I left out the rainclosing. Does that work as exprected or is enabling just a "doen't hurt to enable it" thing. I was told it doesn't work as expected in a Passat. The guy that did the coding for me (I currently don't have VCDS myself) was a bit reluctant to change Byte 18, but as it didn't work without he trusted me on this, as I already read that it is working for others with a BlueGT as well on here.
So thank you a lot again! No I just have to find a way to make the relay fit into the ... relaything... don't know the name. I guess I need a different socket or something like that.
Cheers!
Bad thing because the problem of button illumination is within the control unit.Mart!n-GTI-DK wrote: Doesn't work there is no label file in vcds for that
Wiring is not the problem.
No problem if you change the byte18 in your BlueGT.McFrog wrote: Hello again!
Cheers!
You need this adapter relays
Thank you for providing the part number, I couldn't find it myself. Already ordered it and will switch the releay socket once it's there. I like things looking like everything is OEM.
