ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
Advised by ciclo, I used a mcp 2.8 connector
First the wire from pin 6 -diode- to interior light:diskoboy wrote:I've finally replaced the 6R0 BCM with the 7E0 BCM.
Currently I have some small issues that I'm looking into:
- Highbeam stalk is not working. It's working if I pull the stalk agains me. Then the high beam is on. If I push away (and it automatically goes back into normal position) from me nothing happens. I've replaced the original with "7E0 953 507 B 9B9". I've can't find any measuring blocks where I can see if it works or not. Any ideas? Do you know what wires that it's using?
- Keys... I've adapted both keys and in the measuring blocks I can see that all 6 buttons (2 x 3 buttons) are working/registered, however I can only unlock the car and use the "trunk"-button in the middle. The "lock"-button is not working.
Any ideas on the 2 above issues? And the one below...
The wire from pin 6 (camera) / diode - should it be connected to this 'pin' on the interior light ?ciclo wrote: 2-Mirror-camera-BCM-IC:
Click here to enlarge, download, etc...: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Yes, but the diode must be connected in the other direction to that shown in your image. In the other leg (red paper).
Contact-terminal I have used. (it is in my topic )
New stalks:
Do you have rewired all wires from the T41 stalks connector (38,39,40,41) to the BCM and fusebox as in the diagram? https://drive.google.com/file/d/0B2nv91 ... luc3M/view
Do you have coded the 54 BCM adaptation channel?
Some BCM coding: Byte20 60 HEX (without external gateway), Byte28 08Hex.
Keys (remotes):
Is your 7E0 BCM new?
Do you have removed forever your external Gateway as indicated in other occasions?
Please diskoboy, open a new topic to share your issues, and post there all info from your car to be helped in the best way possible. Link me to your new topic.
You already have experience in these matters... (ross-tech forum, etc), I might think you're kidding me or at least you try.
Many thanks, sincerely.
Soon I will post more information on CNK' topic that might interest you.
About the keys... and I'm not kidding (or trying to trick you [emoji12])
Pressing unlock button - it opens all doors
Pressing lock button - nothing happens
Unlocking using the lock cylinder (driver door) - all doors are unlocked
Locking using the lock cylinder (driver door) - only drivers door is locked.
Original gateway has been removed and thrown away as garbage. All can-bus wires has been extended and I can see all modules etc (including door modules).
- Drives: 6R 1,6MPI(CFNA) sedan
I suppose you hadn't deactivated the factory mode of the BCM.diskoboy wrote:.....
09 centr.electr -> adaptation -> 99 channel set 0 value
However, it is explained here and here you had the link, it is the first thing that you had to have done.
Maybe now you understand my questions and my replies to your questions.
The following thing I go to write is not related with you, diskoboy. (maybe yes... )
For the record: I do not like to write the following, and I only do it for reporting since this one is supposed to be my topic.
Why I have blocked the forum messaging inbox?
Because all you have to ask me you can do it directly in the forum, to share with the rest of users. I don't hate to anyone or have those thoughts, the main reason is due to a matter of TIME.
Those who have my email can ask me what they want through my email ... there is only one way to get my email... It's called trust.
lol that explains why my mailbox has been flooded in the past days
iichel wrote:lol that explains why my mailbox has been flooded in the past days
I will continue to try to make people want to share in the forum ... because this Great forum is the place where we met.
Collecting BCM Max info:
6R
7H0 LHD cmoret
7E0 RHD benzinkopf
7E0 LHD CNK
T5.2
7E0 RHD Adam87
- Drives: 1.2TSI 105HP DSG7
Can't wait!![emoji1360]
The wait and travel are usually very important parts of the processes, they are the main reason so the best things in this life take their time to be a reality ... Relax and enjoy each of these moments.benzinkopf wrote:Can't wait!![emoji1360]
Your 6R will be in a new dimension when everything is installed, you can be sure of this. The fact that you do the whole installation will magnify this new dimension.
Hmm ... tell your German friend to be quick to send you all things...
- Drives: VW Polo 6r 1.6 TDI
Hello ciclo
Here is the scan of my Polo 6r with the BCM 7H0
How can I get address 61? Appeared after installing the new BCM and my car does not have it.
Sunday,16,October,2016,17:30:51:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ6RZBY****** License Plate:
Mileage: 70838 Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 10 15 17 19 25 37 44 56
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 G HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 9970
Revision: --H13--- Serial number:
Coding: 00114016002400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02103L 003010
ROD: N/A
VCID: 2A5BE4234D0AF24EEA7-807F
No ASAM data for: "EV_ECM16TDI02103L" (VW36 *)
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 210248E3417200BA842D12E882D700421300
VCID: 8603F09335D2762E2EF-80D3
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 387FCE6B8BA650DE6C3-806D
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0715
Revision: B9074001 Serial number: 0571 116130727
Coding: 7DB02FB848610E0093380E306CAB8ED00F80610F60862001200000010000
Shop #: WSC 36457 123 104857
VCID: 2D51EF3F74E4E5760F5-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 281010 05 54 0403
Coding: 0E302D
Subsystem 2 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T
Component: J387__TSG_BT 006 0902
Coding: 08BC30
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
Subsystem 7 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H07 0013
Coding: 020000
Subsystem 8 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Coding: 08BC32
Subsystem 9 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 56D 919 475
Component: PARKHILFE 8K H02 0106
Revision: -------- Serial number: 35811333101508
Coding: 308002
Shop #: WSC 12345 123 12345
ROD: EV_VW75XParkAssis8K.rod
VCID: 3B75D167B2907BC6811-806E
Component: VW10Airbag01M H09 0020
Revision: -------- Serial number: 003GX00ANB5F
Coding: 00314D
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4A9B84A3ED4AD24E0A7-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405B06JDC6PVZ
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB4053085G2CH2L
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB405504QLU3P1V
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB405704QLU1PE2
Part No SW: 6R0 920 861 F HW: 6R0 920 861 F
Component: KOMBI H04 0304
Coding: 140A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 387FCE6B83A650DE6C3-806D
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-19.lbl
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0715
Revision: B9074001
Coding: 002200
VCID: F0EFB64B2356489EE43-80A5
Component: IMMO H04 0304
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EADBA4230D8AB24EAA7-80BF
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H04 5238
Revision: AB001001 Serial number: VWZ6Z7K3029008
Coding: 04000440010000A10001
Shop #: WSC 72796 133 80617
VCID: 377DCD5786B85FA6659-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V12 8195
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F6DF537EAE897663D9-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
End ---------------------------------------------------------------------
You have two options:
1- VCDS---> Gateway--> Installation List ---> Unmark 61 (Save/Do it)
2- Install the battery monitoring unit. Click here (Thanks to ZZZhuk )
The only function that it would have in your car (which is not bluemotion) would be to have knowledge of battery parameters through the VCDS.
Also, if you want... read here more information about it (very interesting) in firegrafik logbook.
Btw, I am glad to see a BCM Max installed in your car without my help. Good job.
I have absolutely the same issue. This is because the BCM was used,not new.gti16 wrote:Hello ciclo
You should mark 61 control unit in the 19 Gateway's installation list. After than you should open 61 Battery Regulator and set the all bytes(at least 0 Byte) of the coding 00, after that exit from the 61 Battery Regulator, again to the 19 Gateway's installation list, unmark 61 Battery Regulator. Profit.
Perhaps just have to clear (61) in the installation list of his 7H0 BCM. I have done it several times in 7H0 and it worked.
However, the information you provide is excellent in case of having the same issues.
Let's wait for his results. (otherwise I will never help him again... just kidding)
May i know in details whats the function provided by the Battery Regulator? I thot it is critical where the module can monitor your low battery level and shut down unnecessary equipment for one last engine start? I ve thought once to install the module, but I'm not sure whether the function that i want like above is there or not.
