Coilover issues/Knocking noise
Hey guys just change my coilovers from TA Technix to FK Silverlines, i'm using the same adjustable droplinks i did before, the FK's are about a cm lower than the TA's. The issue i'm having is the left strut is knocking like mad, the right does it a little if i hit a big pothole, topmounts are tight and everything else seem tight... anyone care to shed some light? maybe fitting the standard 6R droplinks? could it be the ARB? I didn't get time to check as it's dark now... so anything i could try tomorrow would be great!
