BlackPoloBM
blackpolobm
Drives: Polo Bluemotion
BlackPoloBM
Post by blackpolobm »
Hello, I am BlackPoloBM from The Netherlands, and I have a Polo Bluemotion 2011.
I changed a lot of things on my car:
- Front R-line bumper
- Front R-Line grill
- OEM Bi-Xenon headlights (I have issues with the led lights that CANBUS shuts down after driving @ciclo could you help me with this please?
- Back GTI bumper
- GTI interior
- GTI steering wheels
- Golf 7 GTI rims
As mentioned. I have OEM bi-xenon headlights and I have a adapter which I use with the headlights so that all the functions of the headlights will work on my Bluemotion.
But there is just one problem. After driving 2 seconds, CANBUS is turning my LED lights OFF in my headlights.
I heard that other people had the same problem and that you must change a code in VCDS.
The problem is, I do not have VCDS and I do not know how to work with it.
I heard Ciclo knows how to solve this problem.
PS: My future updates will be: BlueGT speedometer and Polo 6C taillights.
Cheers.
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Re: BlackPoloBM
Post by Mart!n-GTI-DK »
Really nice looking Polo. :P
Re: BlackPoloBM
Welcome blackpolobm,
Excellent combination of bumpers, rims and other details. I like it. 8)
We hope to see some pictures of the interior.
Your problem with original xenon headlights is easily solved with coding, the real problem you have is that you do not have VCDS.
Ask for help from a close friend to do an AUTOSCAN and post it here. :wink:
blackpolobm
Re: BlackPoloBM
Thanks for the reply and thanks for the compliments. I will update my page with more pics soon.
I found a guy who made an auto scan with VCDS. I hope you can see what the problem is.
I also found out that my tail lights are not working any more cause of this problem.
Here is my autoscan.
Sunday,15,March,2015,15:10:48:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ6RZBY236425 License Plate:
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 15 17 19 25 37 44 56 61
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (J0000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 907 425
Component: R3 1.2 DCM3.7 H06 8510
Revision: 12005001 Serial number:
Coding: 00114014032401080000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM12TDI03103P906021B 001026
ROD: EV_ECM12TDI03103P906021B_VW25.rod
VCID: 275D1D175E18CF26F59-8072
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Coding: 210224E3417000B8842924E482D600521300
Shop #: WSC 00788 648 00255
VCID: 871DFD9732D86F26559-80D2
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326BFC436DDABA8E527-8067
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 D HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0322
Revision: BU046001 Serial number: 0379 036110912
Coding: 3CB02BBF08A1000000280DB07E2B0CD0DF8065FF7E860441A00000000000
Shop #: WSC 12469 483 00190
VCID: 3F8DA577AE8867E6AD9-806A
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 007 1611
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 1611
Coding: 48BC30
Subsystem 3 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H07 0013
Coding: 820000
2 Faults Found:
007 - Short to Ground - Intermittent
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 108
Mileage: 109653 km
Time Indication: 0
Date: 2046.14.14
Time: 15:02:21
03432 - Activation of Right Parking Light
Fault Priority: 2
Fault Frequency: 1
Reset counter: 108
Mileage: 109653 km
Time Indication: 0
Date: 2046.14.14
Time: 15:02:21
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag01M H09 0020
Revision: -------- Serial number: 003GX00FAA01
Coding: 00314D
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4A9B84A3ED4AD24E0A7-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405P0ATOCB07U
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB405P0ATOCDP08
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB4057058P0D9E/
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB4059058P0896U
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 F HW: 6R0 920 861 F
Component: KOMBI H05 0114
Serial number: 00000004611944
Coding: 140A00
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01013
ROD: EV_DashBoardUDSJCIPQ25_VN81.rod
VCID: 387FCE6B83A650DE6C3-806D
Address 19: CAN Gateway (J533) Labels: 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H38 0025
Revision: H38 Serial number: 300111F2003523
Coding: 2500C2
VCID: 3365F94792C0B386591-8066
Address 25: Immobilizer (J285) Labels: 5K0-920-xxx-25.clb
Component: IMMO H05 0012
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
ROD: EV_ImmobUDSJCIPQ25_SK25.rod
Address 37: Navigation (J794) Labels: 3C0-035-270.clb
Part No SW: 3C0 035 270 B HW: 3C0 035 270
Component: RNS310 H19 0357
Revision: 11000000 Serial number: VWZ1Z2L7244806
Coding: 000004010200000100000000
ASAM Dataset: VW_RNS310 A02007
ROD: EV_VWRNS310UDS.rod
VCID: 19392BEF186C69D673D-804C
3 Faults Found:
1048595 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 3
Reset counter: 68
Mileage: 93724 km
Date: 2038.14.13
Time: 10:23:50
1048596 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 3
Reset counter: 68
Mileage: 93724 km
Date: 2038.14.13
Time: 10:23:50
1048632 - Antenna 1 for Radio
B1119 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Mileage: 93724 km
Date: 2038.14.13
Time: 10:23:56
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F6DF537EAE897663D9-807A
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0025
Coding: 030B1A5A
VCID: F4E7BA5B574E74BE00B-80A1
Subsystem 1 - Part No SW: 6R0 915 181 B HW: 6R0 915 181
Component: J367-BDM H07 0150
End ---------------------------------------------------------------------
Re: BlackPoloBM
I would suggest:
3CB02BBF08A1000000280D917E2B0CD0DF8067FF7E860441A00000000000
Re: BlackPoloBM
IZVVC
Re: BlackPoloBM
Post by IZVVC »
Car looks absolutely amazing mate, where did you get the alloy wheels from?
dimblue
Drives: polo 6r tdi dsg
Re: BlackPoloBM
Post by dimblue »
hello i am jim from athens and i have a polo 1.6tdi dsg no bluemotion.it is possible to update my cluster to gti and how? ciclo wrote in the past if i remember right the gti tacho is only for petrol,not for diesel.can you help me??
Re: BlackPoloBM
you have to find a gti tacho first, but it will work in a diesel too. i got one in a 1.2tdi and works fine.
saty
Drives: Polo 6r 1.6tdi
Re: BlackPoloBM
Post by saty »
iichel wrote:you have to find a gti tacho first, but it will work in a diesel too. i got one in a 1.2tdi and works fine.
How does the rev counter work? Is the needle synced with the gti counter or does it move as if the old counter was in.(As the diesel only has revs up to 6k)
Love the work on the bluemotion!
Gannu
Drives: 6R 1.6 TDI 105 PS
Re: BlackPoloBM
Post by Gannu »
The GTI tacho doesn't have issues if it is used on a diesel car. I have a GTI tacho on my 1.6 TDI. Tacho works just like the stock one but the downside is the lack of the glowplug warning light on the GTI cluster. I am guessing the LED is not soldered on the board.
For swapping the cluster, the immobiliser code from the stock cluster needs to be recoded to the new cluster and the car keys have to be sync'ed. I couldn't get the VW service center to do this so I referred to an afetrmarket VAG specialised guy who did the work.Shipped the stock cluster to him along with a spare key. He shipped the new cluster with the key coded. I swapped it and it worked fine.
Re: BlackPoloBM
Whether the dealer will do it or not is not very equally distributed. Some will do it with pleasure, some refuse.
Important to keep in mind is to buy a tacho with 0km. Or less than 200. Higher than 200km needs a specialst to build it in, lower can be done with a dealership.
The glow plug light is being substituted by the EPC light in function. De paticulate filter warning is now on the pixel screen.
Gannu
Re: BlackPoloBM
Post by Gannu »
iichel wrote:The glow plug light is being substituted by the EPC light in function. De paticulate filter warning is now on the pixel screen.
iichel, I don't get the EPC light on my cluster. Is there a way to get this light activated? Can VCDS be of any use here? I only get these lights when I turn the key to ACC before starting the engine.
Image Image Image
And they turn off when the engine is started and the parking brake is released.
Re: BlackPoloBM
It should be activated when you have it built in at a dealer
dimblue
Re: BlackPoloBM
Post by dimblue »
thank you very much for the answer iichel...
