Dash cam
- Drives: Polo gt bluemotion
Dash cam
Hi I've just purchased a blackvue camera which I'm going to install over the weekend can anyone tell me what's the best way to hard wire it into the fuse box and what fuse to use.....thanks
- Drives: Polo GTI 6C - Flash Red
Re: Dash cam
i wired mine into the 12v cig lighter fuse, with an adapter that came with my next base dash cam. i ran the wire without removing any trim. You should find that you can pull the rubber trim round the door away enough to push the cable in.
the hardest bit was getting the cable through a small hole that was already in the fuse box (under the steering wheel, just pull off the panel).
i can sort photo's if you need them.
Re: Dash cam
Thanks mczZippy could you sort them out if you don't mind I'm not very good at doing stuff like this cheersMczZippy wrote:i wired mine into the 12v cig lighter fuse, with an adapter that came with my next base dash cam. i ran the wire without removing any trim. You should find that you can pull the rubber trim round the door away enough to push the cable in.
- Drives: 2016 R-Line TDi
Re: Dash cam
Interesting. I leave my dash cam cable dangling over the touchscreen and it gets in the way.MczZippy wrote:i wired mine into the 12v cig lighter fuse, with an adapter that came with my next base dash cam. i ran the wire without removing any trim. You should find that you can pull the rubber trim round the door away enough to push the cable in.
I'd like photos please
Re: Dash cam
You can buy a kit off eBay so you don't have to use the 12 volt cig charger, I'm putting my cam next to my rear view mirror and using the interior light as its power source
Re: Dash cam
Well finally got the dash cam installed today thanks for all you comments much appreciated
- Drives: 2015 GTI
Re: Dash cam
i don't know which fuses are for you dashcams but if it's the 15A ones i'd highly recommend you change them to 5A tops
Re: Dash cam
Well it's the same fuse what's used for the cigarette lighter what it plugs intoDink wrote:i don't know which fuses are for you dashcams but if it's the 15A ones i'd highly recommend you change them to 5A tops
- Drives: 2015 GTI
Re: Dash cam
that allows for things to be plugged into the cigarette lighter socket
but being as you are coming off the fuse box directly i'd fuse your dash cam supplies to 5A tops
Re: Dash cam
Can you get both supplies of the mini fuses like?Dink wrote:that allows for things to be plugged into the cigarette lighter socket
- Drives: 2015 GTI
Re: Dash cam
just get a couple of 5A fuses of the size you have and stick them in the ones for your dash cams (i'm guessing you have separate supply for front and rear cams)
ebay link
ebay link
Re: Dash cam
No it powers two cameras
Re: Dash cam
So keep the original 15amp fuses that I pulled out of the fuse box then put 5amps onto the piggy back for the cameras
- Drives: 2015 GTI
Re: Dash cam
so what is the other one for? you have 2 add a fuse things installed
yeah whatever fuse was already installed stick that back in for the original circuit
then install 5A fuse for the camera supply
Re: Dash cam
Oh I see thought it had to be the same size fuse as the original thanks for that Dink appreciate it thought I'd done a good job as well lol
