peter_dk25 wrote:No, it is not true.
You can choose which bulbs you want the system to check.
It is done by using VCDS - 09 - long coding......
So Peter can you knock all the canbus of so I could change every bulb on the car to led and no warning light will come on
On the new brain you can code every light no problem but not from long coding you need to code over adaptation [emoji106] what Peter wrote is not long coding its adaptation
Tapatalk kullanarak iPhone aracılığıyla gönderildi
Well guys I'm sorry but you have lost me here?i thought it was just the case of swapping the bulbs over, didn't realise it was going to cause problems with the system looks like I'm stuck with a load of bulbs what I can't use
Find someone with vcds Vagcom and I can help you sir
