Polo gti 6r dab aerial confusion
Hi lads and girls
New to polo forum always had volkswagen but have come from golf. Just having a little bit off trouble with dab in polo unit has got black dab connector on rear off unit and also has the amplifier in rear window but it has only got one fakra connector on it and I thought it should have too as can't get any signals at all is it just a case off swapping the amplifiers over
Cheers Gordon
Cheers Gordon
Re: Polo gti 6r dab aerial confusion
DAB+ reception goes through the aerial and amplifier on the roof
Right now I am confused so could it be the roof aerial then that is causing the problem then
peter_dk25
- Drives: Blue GT
As iichel says the DAB+ signal in the Polo goes through the Ariel on the roof - factory made.
You can make an aftermarket solution by changing the amplifier in the rear window with one capable of receiving both FM and DAB+ signals like this:
https://www.kufatec.de/shop/de/nachrsts ... -vw-golf-6
I have it in my Polo - Works perfect!
So I just take my original amplifier out put the new one in and run cable from the amplifier to my headunit where would you say it's best to run this cable through head lining or down through sils trims thanks for help buy the way cheers Gordon
peter_dk25
- Drives: Blue GT
Yes - quite simple to do.
Through the trims are the easy way to do it.....
Hi thanks for this have ordered one and as soon as it gets here will let you no how I get on thanks for this
peter_dk25
- Drives: Blue GT
Right guys update fitted new aerial from above and it still says no esemeble what else could this been was a costly mistake any help would be appreciated
Cheers Gordon
Cheers Gordon
peter_dk25
- Drives: Blue GT
How is your FM reception?
Perhaps you have reversed the two connections on the amplifier in the hatch?
Hi what do you mean the reception in car is now crackly I have swapped over orignal window aerial
peter_dk25
- Drives: Blue GT
There are two connections going into the amplifier module:
One for the FM signal and one for the DAB signal.
Try swapping these two connections and see if it helps.
Right got you will just try that now and see what happens
Hey Peter sorted it had to plug the orignal plug back in into widows areial as well and bingo all stations came alive thanks for all help
peter_dk25
- Drives: Blue GT
