standard headunit help, how do you turn it on
rik19
Drives: 6n1
Post by rik19 »
Hi guys, ive just got a standard headunit for my polo off ebay, came with code etc, ive plugged it in, a red led is flashing on the front...
question is how do you turn it on etc...ive tried holding the volume buttons down the volume etc
sounds daft, i dunno how you turn it on,.. :( to even enter the code... :|
one of these just found this pic online, its one like this
thanks if anyone can tell me..:)
Re: standard headunit help, how do you turn it on
The left knob - you push it in
nats148
Drives: 2015 1.8 GTI - Golf Anniversary
Post by nats148 »
Press the volume button in
Sent from my LG-D855 using Tapatalk
Im sure ive seen this issue before actually
Check the fuse - its quite possibly blown.
rik19
Drives: 6n1
Post by rik19 »
thanks for the replies guys...
pressing the left knob it wont turn on
the fuse is ok..
ive tried holding down all the buttons now, still wont turn on..
the red light flashes on the front untill you turn the ign key it then goes off, been trying for about an hour, wont come on....hmmmm
I think this is to do with there being no K-line feed on the 6n polo. I'm not even sure if there's a way around it
rik19
Drives: 6n1
Post by rik19 »
k line feed? is cos i dont have a cd player bit or something...
It's the predecessor to canbus. The radio communicates with the ECU on more modern Polos and checks in
rik19
Drives: 6n1
Post by rik19 »
after a lot of searching it looks like i need to loop a power wire to another pin to make it work..
That rings a bell
rik19
Drives: 6n1
Post by rik19 »
fixed now, had to join the power pin to the one next to it, as my polo had no wiring in the connector for it..
works now, yes the volume button turns it on and off..:)
Happy days :)
rik19
Drives: 6n1
Post by rik19 »
cheers, looks way better than the aftermarket one i got when i bought the car, hate when people change em, and it sounds better too.. :D :D :D :D :D :D
