Changing hydraulic tappets (and rockers?)
The tappety noise is annoying me so planning to replace the hydraulic lifters at approx. £80 a set. I have someone to do the work for me for a modest fee. Would it be necessary/recommended to change the rocker arms at the same time? I have read different opinions on whether they should be done or not (some say the rocker wears in on the cam and changing them is not advised).
Re: Changing hydraulic tappets (and rockers?)
I would only change the tappets
Thanks. I'll do that then. I heard that INA tappets are quieter than Febi.
Febi are generally as good or better than OEM quality. I would probably sway towards them as I have had no issues in the past
