my boot light keeps coming on, on my dashboard and it is really annoying
me and my m8 had a quick look around in a car park in the dark and couldnt find anything but obviously wasnt the best of looks.
any ideas what it could be?
or have any of you had the problem b4?
boot light
- Moderator
need the tailgate stripping down and hose reconected .
you might just wanna clean the wire counecters too use either wd40 or a contact cleaner
on the unlucky side you might need the termals replacing as they have a tendancy of breaking when they been corroded for a while and you my need a new boot lock
this is commen on the full vw range ive repaird 2 just today normaly caused by trying the washer jet when the jet is frozen the preasure builds up and pop gos the pipe
other commen places on a polo is just behind the abs pump
the genuine vw repair procedure is the connecters cut off the pipe ends and rejoined with small bore rubber pipe and secured with crimp clips
