Sounds like you've got a 2 channel. It should be bridgable (most amps are), meaning you use one positive from one channel, and a negative from the other channel. It's best to use this function for a Sub.
right sorted this now however when i connect the battery and the amp comes on, i get like a pluse through the sub even when nothings playing..
any idea how to stop this?
constantly tim., the wires are all routed seperatly so it cant be that..
when i connect the power its pulses and when i turn the engine on it pules faster..
any ideas?
hmm that's a little strange. I can't think of anything it can be without doing research. have you checked that the remote cable is properly connected to the correct places on the amp and headunit? Checked it's a safe ground and checked the live wire is good? They all must be properly crimped and secured in place. not just bare wire twisted into positions.
right this is sort of sorted now..
however when i turn the power input up on the amp from 6V to the higher setting it happens.. what should it be set on?
