polo TSI lowering advice
winky666
Drives: polo tsi
Post by winky666 »
I have recently purchased a 10 plate polo 1.2 TSI sat on 17" boavista alloys. It looks like a bit of a monster truck on the rear so im looking to get it lowered.
What would people suggest I should lower it by? Baring in mind my wife will be driving it with no acknowledgement of speed bumps. Also I dont want it rubbing with 2 adults in the back.
Thanks in advance
Ste j
Drives: 1.2tsi
Re: polo TSI lowering advice
Post by Ste j »
Mine is on h&r 25/40 and sits just right in my opinion ride is fermer but fine no rubbing at all.
winky666
Drives: polo tsi
Post by winky666 »
that looks sweet. have you had 2 adults in the back? I thought mine had been on a jack and hadnt settled at first lol
saty
Drives: Polo 6r 1.6tdi
Post by saty »
+1 on the H&R 25/40
Ive got the 35/55 and the ride is really harsh, really harsh. Youll be fine with two adults in the back, had three in the back of mine and no rubbing on my 18s.
robertsm66
Drives: VW 1.2 TSI
Post by robertsm66 »
Ive got black Boavistas. Just lowered mine 25/40 H & R sport. Ride is fine and not massively different to standard. Car feels far more planted.
Also getting 5 mpg more since the lowering which is weird.
I can recommend spacers 10mm each front corner and 20mm each rear corner. Car looks better and is more sure footed
Image.
winky666
Drives: polo tsi
Post by winky666 »
thanks for the replys. ill look into the spacers. iv seen the springs that ratio on ebay.
robertsm66
Drives: VW 1.2 TSI
If your doing it yourself, let me know and I'll give you a list of tools you'll need as there's a couple of tricky buts with special tools required.
Tooks
Drives: 2011 Polo GTI
Post by Tooks »
As above, the H&Rs along with the Eibach Pro Kit will drop it without it looking stupid.
For DiY, spring compressors and ball joint splitter are the only specialist tools needed.
I don't think many people do, but after a drop that big, you should get the tracking done and also get the headlight aiming checked as the range will be slightly reduced after the lowering.
winky666
Drives: polo tsi
Post by winky666 »
thanks. ill be letting my brother do it hes a fitter. Are the spacers required?
winky666
Drives: polo tsi
Post by winky666 »
Tooks wrote:As above, the H&Rs along with the Eibach Pro Kit will drop it without it looking stupid.
who would check the headlight aiming vw?
winky666
Drives: polo tsi
Post by winky666 »
Ste j wrote:Mine is on h&r 25/40 and sits just right in my opinion ride is fermer but fine no rubbing at all.
do you have spacers on this?
saty
Post by saty »
The spacers aren't necessary, they just give the car a better stance
The headlight aim can be checked by any mot test station
winky666
Drives: polo tsi
Post by winky666 »
saty wrote:The spacers aren't necessary, they just give the car a better stance
thanks.
Ste j
Drives: 1.2tsi
Post by Ste j »
No not yet but going to get some 15mm for the rear and maybe 10mm for the front
bessos
Post by bessos »
I will have some 2 month old 25/40 h&r spring available at the end of next week if you are interested?
