All6R.Emergency Brake Flashing (Brake light) active.(TESTED)
This feature only can be enabled for first year of production of Polo 6R.
The solution to get this feature on Polo 6R (since Nov 09) is to run a wire from T4e/1 brake switch connector (splicing to the existing wire) to BCM white connector T73b/42 (check before if your BCM has this pin).
Brake switch connector is beside the brake master cylinder (engine bay).
RHD T4e, grey connector on image
LHD T4e, C on image
Also you must activate Byte 12 bit4 on BCM, Address 09 Cent. Elect.
... if you do it please tell us your results.
Re: 6R.Emergency Brake Flashing (Brake light) active.(UNTEST
I found that my daughter's late 2009 Ibiza 6J has this enabled and with the "Turn Signals Flashing" when I was checking the (6R0) BCM coding!
I'm surprised that any wiring changes are needed for this to be activated in Polo 6R - just goes to show that when dealing in large numbers of cars being built, VAG did not just have a few common wiring harnesses (across the marques - Fabia, Polo, Ibiza, A1) to drive costs down.
I think this issue is related to the location of the brake switch. Before it was located on the brake pedal and now is beside the brake master cylinder.
Perhaps this wire was removed on models with the brake switch beside the brake master cylinder due to eliminate production costs, but the BCM remains the same, in any case the ABS module is connected via CAN bus and with a software update from the factory this feature also be possible without wire. Before and now.
lxm
Post by lxm »
I enabled 'emergency turn signals flashing'
When I break Very hard my hazard lights flash 5 times....
Can confirm this to be working :-)
Doc_House
Drives: 2015 VW Polo SE and 1972 GT Beetle
Post by Doc_House »
Was enabled on my old 6R and is a working feature on the new one
lxm wrote:I enabled 'emergency turn signals flashing'
And your brake lights? (as shown in the video)
From what year is your Polo?
If you look carefully at the video the brake lights flash before the car stops, and after when the car is stopped hazard lights (turn signals) begin to work.
This feature can anticipate braking rear car driver. :wink:
Golf VI
Doc_House wrote:Was enabled on my old 6R
Model Year? :arrow: http://www.uk-polos.net/view ... 09#p478942
iichel wrote:Can confirm this to be working :-)
Perfect!, you're great. Image
Doc_House
Post by Doc_House »
It was new from dealer stock in 2012 so could be my 2011/2012
Re: All6R.Emergency Brake Flashing (Brake light) active.(TES
Ok, thanks for the info. :wink:
In any case, if someone tries to enable this feature and is "rejected" in the VCDS program already knows what to do to enable it.
aaygen
Drives: 6C 1.2 TSI Lounge
Post by aaygen »
Is there any info on how to do this and the blinkers on a 6C? Enabled something relevant from adaptations with a 14.10 cable but the car doesn't turn on the blinkers after emergency braking
aaygen wrote:Is there any info on how to do this and the blinkers on a 6C? Enabled something relevant from adaptations with a 14.10 cable but the car doesn't turn on the blinkers after emergency braking
Doc_House wrote:Was enabled on my old 6R and is a working feature on the new one
Perhaps Doc_House can help you in this matter for the 6C.
aaygen
Post by aaygen »
Oh I haven't seen his post. I haven't checked if the brake lights are flashing or not so it might be already enabled as Doc_House posted, I just know that the blinkers don't work after braking. I'll wait for his response and see what I can do then, also I'll check the brake lights in the meantime
AVENOX
Drives: advance
Re: All6R.Emergency Brake Flashing (Brake light) active.(TESTED)
Post by AVENOX »
Hello fellow ,i am with the translator i am sorry for not to speak or write English ,but i have problems with the activation of the flashing lights of emergency and brakes ,and wiring the bcm and activated the bit .and i am not work .done all accurate as e read ,i ask help to be able to make that work many thanks
