Weird fuel gauge behaviour
So a funny thing happened tonight on my usual drive from the west of Scotland to Manchester.
I'd filled my Polo (65 plate R-Line 110ps) and noticed that my fuel gauge didn't shift from full for about 200 miles. Then went down a tiny bit. Usually I'd see the needle start to move after about 70 or so miles so this was really bizarre.
So after 234 miles, with an average mpg of 52.9 (which is fairly average for this journey usually),the fuel gauge has moved only 1 and a half sections and my range was still 395 miles, which seem pretty crazy. Usually after this drive, my fuel gauge would be somewhere between 1/2 and 2/3 full.
Anyone ever seen something like this before? Any ideas how to fix it?
- Drives: 2015 blueGT
Re: Weird fuel gauge behaviour
Jees, that's better than the BGT which is meant to be an eco car haha. That does seem weird that both the gauge and range indicator seem to be wrong.. Perhaps check the manual to see if there's a reset for it? Not heard of it myself
It is weird isn't it! Can't find any mention of resetting it anywhere, so I guess it's back to the garage to get it looked at.
I know that fuel gauges aren't particularly accurate (I used to have a VW up! that could go about 110 miles before the needle moved! And that was considered normal) but I'd like some confidence I'm not gonna run out of fuel randomly without realising it.
Are you sure that you have not just "force filled" the tank beyond the usual first or second click? I've done that a few times with my wife's August 2015 Polo 1.2TSI 110PS SEL - in fact I think that the current tank of fuel is still at "full" after quite a lot of miles - I don't normally deliberately over fill the tank, but sometimes that is what happens and will be reflected in the miles this fill will last.
Remember the "trip" miles being displayed can be false as it needs to be reset manually.
Yeah, I guess it could have been down to overfilling if it were a small difference. But to do 200 miles and it not move at all, surely there'd have to be a heck of a lot of extra fuel between first click and whatever I'd filled it to?RUM4MO wrote:Are you sure that you have not just "force filled" the tank beyond the usual first or second click? I've done that a few times with my wife's August 2015 Polo 1.2TSI 110PS SEL - in fact I think that the current tank of fuel is still at "full" after quite a lot of miles - I don't normally deliberately over fill the tank, but sometimes that is what happens and will be reflected in the miles this fill will last.
I'm only really worried because it was on a trip that I do fortnightly, so I'm used to when and where the needle starts to go down.
RUM4MO, how much extra fuel can you get in your wife's Polo by force filling? I've never tried it, at least not deliberately...
Humm, 200 miles at 60MPG, is still roughly 15 litres!
I get the impression that with some filling station nozzles, you can end up "under" filling easily by that amount, which can be annoying, for "over" filling, and this is just a guess, I'd be thinking that 5>10 litres is easily possible, so that is getting up to where you could be if you forced the last 5 litres in by venting.
If I were to make a generalised statement wrt VAG fuelling, the first "half" of the gauge travel is normally optimistic and the second "half" is frighteningly pessimistic! So, over a full tank's load of fuel at a constant MPG, the first "half" travel would be reached after 65>70% of the actual range, so the second "half" of the gauge travel would be used over the remaining 30>35% of the range - well maybe that is exaggerating a bit!
I agree with that statement.. My moves after 50-60 then moves quickly to 1/4 tank used (normally 130/140 miles) then the last quarter of the tank I'll usually get 70-85.. Really stupid how they behave tbh lolRUM4MO wrote:Humm, 200 miles at 60MPG, is still roughly 15 litres!
- Drives: Awaiting delivery of 6C GTI 5dr
I used to be able to squeeze an additional 5 litres (i.e. just over a gallon) into my 2011 Seat Ibiza. I would guess the Polo is similar.
Its a small overflow tank, which can be filled if you insert the pump nozzle a particular way. The end result is an extra 50 miles on a full tank, and the gauge showing full for longer
Sent from my SM-G920F using Tapatalk
d7lan, it is not a separate overflow tank, it is the top of the fuel tank that is meant to be left free of fuel initially so that any thermal expansion moves the fuel level up into there and not out the vent, or in the case of modern cars - into the pipe leading to the EVAP canister - or even into the EVAP canister, which can be problematic.
Thanks for the replies guys!
The original reason I was worried that my fuel gauge was busted was because I had recently had my dash instrument cluster replaced due to the issue where the trip button gets stuck in, which seems pretty common! Had the car looked at yesterday by VW and they couldn't find anything wrong with it, so I guess either my car is amazing and suddenly gained magic fuel saving abilities, or I/the fuel pump overfilled my car .
Fair enough, I too might have been a bit concerned if other issues just happened after this repair, hopefully over the span of the next few tank fills you will get closer to what is happening and either trust the car or get it in for sorting properly.
Re: RE: Re: Weird fuel gauge behaviour
You learn something new every day! I had read that on the Seat forum. Should know not to trust everything on the internet. CheersRUM4MO wrote:d7lan, it is not a separate overflow tank, it is the top of the fuel tank that is meant to be left free of fuel initially so that any thermal expansion moves the fuel level up into there and not out the vent, or in the case of modern cars - into the pipe leading to the EVAP canister - or even into the EVAP canister, which can be problematic.
- Drives: 6C 2016 R-Line 1.2 90PS - Blue Silk
Explains how I got 51 litres into mine on one occasion
51 litres, 51 litres? I ran my wife's August 2015 Polo 1.2TSI 110PS SEL down to about 20 miles range on Sunday night (518 miles) and managed to force 41 litres into it, that is the most (equal) that I have ever stuffed into it - and I know that I should have stopped at 39 litres!!
Official tank capacity is 45 litres
