Red GTI grille badge
rab90
Drives: Polo GTI 6C
Post by rab90 »
Hi, I've seen a few people have swapped their chrome badges for the red ones. Just wondering if anyone can tell me how the fit them.
I've found the oem badges for both the polo and the golf but the clips on the back look completely different;
http://www.ebay.co.uk/itm/NEW-OEM-Genui ... 2625141066
http://www.ebay.co.uk/itm/VOLKSWAGEN-PO ... 1798729901
MichelKasapovic
Drives: Polo 1,2 tsi 90bhp 6r,6c
Post by MichelKasapovic »
Looks strange, dont know how they should click it to the grill? Maybe all the clips would fit when clicking on to the honeycomb
Re: Red GTI grille badge
May not be a new red GTI badge, but a red vinyl badge skin applied to the existing chrome badge.
http://www.badgeskins.com/polo.html
fivelittlefish
Drives: 2016 GTI
Post by fivelittlefish »
I cut the clips off and used double sided foam numberplate tape to fix it.
rab90
Drives: Polo GTI 6C
Post by rab90 »
fivelittlefish wrote:I cut the clips off and used double sided foam numberplate tape to fix it.
So the original badge will unclip from the grille and the red one can be stuck on in its place?
fivelittlefish
Drives: 2016 GTI
Yep
rab90
Drives: Polo GTI 6C
Post by rab90 »
fivelittlefish wrote:Yep
Cheers, didn't fancy picking all the letters off each badge and being left with both in pieces!
Will I need to get behind the grille to remove it or is it a just case of being firm but gentle?
fivelittlefish
Drives: 2016 GTI
Hmmm - I was firm and not particularly gentle. With a dremel.
I couldn't get the grill off anyway.
rab90
Drives: Polo GTI 6C
Post by rab90 »
A dremel to get the original badge off?
Maybe I should just go for the those badgeskinz [emoji23]
MichelKasapovic
Wrap it
rab90
Drives: Polo GTI 6C
Post by rab90 »
MichelKasapovic wrote:Wrap it
I could but the its the performance pack style badges from the golf I'm looking at. Red with a chrome outline
MichelKasapovic
Oh. Looks better
fivelittlefish
Drives: 2016 GTI
Another option:
Remove just the letters from the plastic plate on the grille using fishing line (like you would on the boot) and then buy a boot version of the badge (i.e. just the letters) which you can then stick to the plate which is still attached to the grille.
Olivier
Drives: Polo 6R GTi
Post by Olivier »
fivelittlefish wrote:Another option:
I did it the exact same way with this result:
rab90
Drives: Polo GTI 6C
Post by rab90 »
I did the same. Really easy to do and no need to take bits off the grill.
