MFSW correct buttons control module
- Jay-Jay
- Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Hi everybody
I've just installed a new MFSW on my Polo 6R Highline MY2010, following the guide posted on here.
The steering and the airbag are recently produced (October 2016), but we are talking about the 6R MFSW.
Unfortunately horn and buttons don't work (they're not even illuminated).
I checked the new wires I installed (+12V and LIN bus) and all is ok.
These are some part numbers:
BCM: 6R0 937 087 D
Steering: 1K8 419 091 BN MFQ
Airbag: 5K0 880 201 AE 81U
Airbag harness loom: 5K0 971 584 D
Buttons control module: 5K0 959 542 C
Because the airbag harness loom I have is specific for Polo produced from 23/07/2012 onward, I changed my slip ring and stalk switch with M.Y. 2014 ones:
- slip ring: 6R0 959 654
- stalk switch: 6R0 953 507 9B9 (without MFA buttons, since they are on the steering)
The problem persists: horn and buttons don't work.
After long searches on ETKA I've noticed that the Buttons control module I have seems wrong:
I have the 5K0 959 542 C, but I should have 5K0 959 542 B, according to ETKA.
This is a picture of the 5K0 959 542 C control module:
This is a picture of the 5K0 959 542 B control module:
They look different!
Do you think that changing the Buttons control module would fix my problem?
Or is the problem somewhere else?
BCM: 6R0 937 087 D
Re: MFSW correct buttons control module
I cannot find it anymore in my PB box, but can you tell us the BCM part number and software version?
(or maybe full autoscan)
- Jay-Jay
This is from the last autoscan I saved, before I changed the coding to activate the MFSW buttons (Byte 9, Bit 3: "Multi-Function-Steering-Wheel (MFSW) installed"):
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 092100132
Coding: 24A02BBF08210000003000003C299CD0BF48670060800001200000000000
Shop #: WSC 12469 483 00190
VCID: 3E794F5CA96CAAE
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Coding: 08BC32
Subsystem 4 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Coding: 08BC32
It should work with either of the two control modules.
We need a recent autoscan to evaluate the problem ...
Edit:
However, it seems that something is not well installed ... check the installation again. Power supply wire, LIN, conectors, etc...
Edit:
- Jay-Jay
Thank you for your help, ciclo!
Here is a fresh new AutoScan:
Tuesday,29,August,2017,13:56:35:37412
VCDS Version: Release 11.11.0
Data version: 20111111
Chassis Type: 6N0
Scan: 01 03 08 09 15 17 19 25 2E 44 56
VIN: *****************
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 D HW: 03F 906 070 D
Component: SIMOS10.20H02 9694
Revision: -------- Serial number:
Coding: 001900D6200400080000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ECM12TFS02103F906070D 003014
ROD: EV_ECM12TFS02103F906070D.rod
VCID: 234F9E282ACEE76
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6J0-907-37x-ESP.clb
Part No SW: 6R0 907 379 AF HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0005
Revision: --------
Coding: 210248E3417200BA842912E982D800421700
VCID: 82017BAC19148EE
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 24 0660
Revision: 00 10 24
VCID: 356B50709C5A696
Coding: 3CA02BB808210000003800003C2B9CD00F48670060800001200000000000
Coding: 18BC30
Coding: 08BC30
Coding: 08BC32
Coding: 08BC32
Component: VW10Airbag00G H08 0020
Revision: -------- Serial number: 003GX000X4FI
Coding: 003047
Shop #: WSC 124697 483 00190
VCID: 4A91138CEDA416E
Crash sensor for side airbag; driver side:
Serial number: 3572SRB40000B0150B1U
Crash sensor for side airbag; passenger side:
Serial number: 3582SRB40000B00D091-
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB405T6DUG679E3
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB405P6NG4E59CV
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H03 0505
Coding: 140A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 336F6E689A2E776
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 D
Component: GW-K-CAN TP20 0207
Coding: 002200
VCID: F0E5216423B88CE
Component: IMMO H03 0505
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
VCID: EAD1330C0D6476E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664346325
Coding: 010100
VCID: 2A51730C45E436E
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 12345
VCID: 2F676218EA06536
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2K7087193
Coding: 0000040102
VCID: 6BDFB6088A9EEF6
End ---------------------------------------------------------------------
I'm keeping an eye on this thread
Sent from my iPhone using Tapatalk Pro
- Jay-Jay
Problem fixed!
I checked again all the connections and I discovered that the new wire I installed for the LIN bus (T28a/16) was not correctly connected!
As soon as I made a good solid connection the horn and the buttons FINALLY started to work!
As always the cause of the problem was a very simple thing!
Here is a quick video I've just made:
Once again, thank you all for your help and support.
I want to take advantage of this topic to ask an information.
Is it normal that using the right buttons, nothing happens if I press the left or right selector?
Shouldn't it goes to the other sections (Audio, Settings, ecc.)?
It seems like I need to press and hold the up/down selector to move to the "home page" and then enter into another section (exactly like I had to do with my old stalk switch).
Duuuuude...
Hold the right side buttons with ignition off, turn the ignition while buttons are pressed
That's great news!
I love how you left the blue wrapper on till it was finished
Congratulations!
Congratulations!
well he lives in italy, so probably never uses the horn anyway.
Jay-Jay, thanks to you for sharing all this information. Enjoy it!!!
- Jay-Jay
Thank you too, ciclo!
Yes, I decided to not remove the blue wrapper untill I would have fixed the problem!
By the way, the city is almost empty during summer and I really enjoy driving around.
Inviato dal mio MHA-L09
Thank you, Chris!chrispy. wrote:That's great news!
Congratulations!
Ahah, in reality we need the horn more than you think! It's full of crazy drivers, especially on motorcycles, that you need hundreds of eyes and it's really difficult to not get mad while your stuck in the traffic of Rome.iichel wrote:well he lives in italy, so probably never uses the horn anyway.
- Drives: Polo Blue GT
When I owned Italian cars it seemed as though the air horns came on with the ignition and only stopped when you turned it off.
Well it seemed like that!
