Hi all,
First post on here as I’m wondering if anyone can help.
Recently replaced my 2 front coil springs on my VW Polo 1.2 2013 following the front driver side spring snapping. Everything seemed well until I noticed a creaking/gear-like noise, which is more frequent when going over speedbumps. Videos attached below of sounds.
https://youtu.be/1vy5Qe2lKME
https://youtu.be/eFBM-NcVoSc
https://youtu.be/fsfpKNrorz8
If anyone has any ideas I would really appreciate it, thanks
Creaking (gear-like) noise from suspension following spring replacement
Re: Creaking (gear-like) noise from suspension following spring replacement
Is everything tied up properly and torqued to the correct values?
What torque values did you use?
Followed the tutorial here: https://youtu.be/Ju7RkVHvaHE
Will try to re-check all bolts tomorrow, or sometime this week. Appreciate the help
Just checked everything, turns out it was a piece of the undertray that managed to come loose and was scraping against the floor! Thankfully noise is gone now
