ABS light on + Handbrake light still flashing after blown fuse replacement
Bomessor
Drives: Polo 9N 2004 1.4 16V petrol
Post by Bomessor »
Hello!
I drive a 2004 9N Polo ( 1.4 petrol ) and I had an issue where the ABS light would come on and the Handbrake light would be flashing and 3 alarm beeps would go off.
After doing some research, I checked the fuses on top of my battery, and indeed, the 40 amp ABS fuse was blown. At that point I was sure that was the issue, and purchased the 40 amp fuse that was needed.
I replaced it, but the warning lights and the beeping didn't stop.
Any ideas what to check next? Could it be a connection issue? I didn't sand the connecting bolts and surfaces, they looked clean to me and were not corroded.
Maarten
Drives: AW R-line Facelift MY2022 Vibrant Violet
Re: ABS light on + Handbrake light still flashing after blown fuse replacement
Post by Maarten »
When was your last brake fluid change?
Are your brakepads still good?
Are all the big fuses good on top of your battery?
Did you run a diagnostic scan?
Module 3 ABS
Bomessor
Post by Bomessor »
Update:
I sanded the connections and took her for a spin, the warning lights finally disappeared.
Maarten
Post by Maarten »
Thanks for the feedback.
Glad is it solved!
