ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Golf 7.5 DCC project. Exterior rear wiring and DCC rear shock absorbers installed.
I have connected the wiring in the interior (rear seat area) using the 'couplings' as shown in previous posts :arrow: viewtopic.php?p=603579#p603579 , viewtopic.php?p=603783#p603783 , both for the shock absorber valves and for the electric parking brakes and speed sensors.
The installation of the new wiring is very simple, the factory wiring is removed and at the same time the new original is installed with the new fixing clips. I recommend pressing the rubber grommet all the way around from the interior area so that the fastening tabs that are molded into the rubber grommet seat correctly.
Factory wiring. New but dirty.
I guess I'll clean it and put it in a box for I don't know what purpose, ... or I'll take it to the recycling.
I installed the DCC Shocks according to erWin, but I used my small trolley jack instead of the spring compressor, it is much simpler if you work on the ground/floor and not on a lifting platform, see images below.
Note:
Once the wheel is removed to remove the shock absorbers, the first thing is to remove the rear level sensor bolt and separate the level sensor from the axle to avoid breaking the sensor.
R
L
RL LS :arrow: viewtopic.php?p=578709#p578709
Unladen position. :arrow: viewtopic.php?p=603171#p603171
A little bit of blue sky, although it turned out to be a mirage, it rained mercilessly again.🤦‍♂️ :lol:
https://www.youtube.com/watch?v=thJgU9jkdU4&t=275s 🎺😍😆
- At the moment, I am not going to install the new original Blue rear brake calipers, which are the same size as the factory ones, I will do it at the same time or a little later than I install the new big Blue front brakes, so the wear of the brake pads will be balanced and the 'single' brake pad wear sensor will do its job properly (I assume).
Everything remains the same on the outside...
It looks like the weather will improve noticeably in a few days (5 or so).🤷‍♂️
Good weekend to everyone!🤗
2.5 + 2.5 + 0.5 = 5.5€
Test.
The following jobs for my DCC project require, in addition to applying pressure on the brake pedal to loosen the front axle bolts, also releasing pressure from the hydraulic brake system to be able to disconnect the brake hoses 'correctly'.
'Hydraulic brake system pressure is released when the brake pedal is fully depressed'.
The Second Mechanic is ideal for these tasks. More info here :arrow: viewtopic.php?p=603218#p603218
As I will have to work/operate with the Second Mechanic on several occasions, I think that with the cheap kitchen boards on the seat will be infinitely more effective than with the cloth on the steering wheel ...in addition to avoiding possible damage to the steering wheel.
By the way, everything remains the same out there,
but it will change...
https://www.youtube.com/watch?v=gAzr2bGitsA
Golf 7.5 DCC project. Installed front left DCC shock absorber.
Installed parts.
- DCC shock absorber.
- Wheel bearing assembly/hub.
- Level sender.
- 312mm Blue Brake (PC57).
According to erWin viewtopic.php?p=597574#p597574, ...and personal experience.😊
Highlights:
Starting point...276mm, FSIII 57.
- One-way valve and press the brake pedal several times until no air bubbles come out of the 6mm inner diameter PVC hose, it is the best and easiest method for a single mechanic. (PVC is better than silicone for this job)
- Having million dollar machines or pumps that put 2 bars of pressure into the system is not a better bleeding method than the one-way valve.
- Loosening and tightening the bleed screw with the 11mm wrench requires skill and absolute precision, the margin between too open, open and closed is very small, this is where most people usually fail by opening the bleed screw too much.
- NEVER use those black rubber bleed caps that are attached to the bleed hose and are supposed to fit "easily" onto the bleed screw. It is the beginning of a great failure.
The brake bleeding system that you have seen in these previous images is an evolved system 🤭 that serves to know with absolute precision the exact amount of new brake hydraulic fluid that you should add to the brake fluid reservoir with another ultra-clean syringe. Also to evacuate the fluid already extracted without removing anything, or to 'initially' extract air from the hydraulic brake system...
This is extremely useful when completely renewing the brake fluid in the entire system.
312mm, PC57.
I think I have stopped having a car, now I have moderately sized brakes and a barely noticeable car attached to them. https://www.youtube.com/watch?v=gpGxIZLcR6w&t=32s
At this moment the flashlights had low batteries so the photo festival is over. On the dark side things are like this.🤷‍♂️
I 'tightened' the axle bolt like this: viewtopic.php?p=603218#p603218
Once the wheel was installed and the car was lowered to the ground, I re-torqued (checked) the three top bolts of the suspension strut mounting.
The sun comes out from time to time and there are good weather forecasts for the next few days, but unfortunately I have to install the front right DCC shock absorber on the dark side.
Cotton clouds or sheep type.
https://www.youtube.com/watch?v=mLlP_ZkONxU&t=162s
Golf 7.5 DCC project. Installed front right DCC shock absorber.
Installed parts.
- Level sender.
Same procedure as for the front left DCC shock absorber, according to erWin and personal experience.
Some images for posterity, not many, today I had to finish earlier.🤭
312mm, PC57.
Never say never again, but I will never work on the dark side again... :lol:
The next thing will be to energize the DCC system = +30/Earth, give it consciousness = +15/CAN lines, and tell it how it should behave = Basic Settings/Adaptations/Codings.
I hope the creature works well and doesn't start out being a new variety of Troll.😄
I guess I'll do it tomorrow, it's expected to be a magnificent sunny day.🌞🤸‍♂️
https://www.youtube.com/watch?v=7D7s9RPUc_o&t=33s
Initial brake test and first sensations/impressions after installing the front DCC struts with new 312mm front brakes. Coding of the new dimension of front brakes.
Friday,05,April,2024,13:18:09:32438
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: NEW BLUE 312mm FRONT BRAKES. NEW FRONT SPEED SENSORS. CODING + TEST. OK!
Mileage: 53014km-32941mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 29 39 3C 42 44 4B 52 5F 65 6C A5
          A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 53014km-32941miles
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000    CVN: 92B19492
   Coding: 01190032234415082000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC92258D-807C
   VINID: 9E69EAAAA465A9B8000041051C011774D2
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA134202170477B060560CA2580562C84E26006A4733420F00A40AA430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DA05F-8022
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 AJ    HW: 5NA 907 044 AJ
   Component: AC Automat    H50 1301
   Revision: 20K03000    Serial number: 00000A00202735
   Coding: 000200032001100D1115004C0018542A
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ACTouchPrehVW37X 001010
   ROD: EV_ACTouchPrehVW37X_VW37.rod
   VCID: 074B66607FAADF526E9-8052
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
   Component: G935 MuFu  H05 0010
   Serial number: AAE88B8400PAG0MUFU05
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 EC    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 1513
   Serial number: 72007150025702 Dataset Number: V03935315NT 0001
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 7DA704882D768582445-8028
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043 0551
   Serial number:         180705074106
   Coding: 0F4DFD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: SBY22M01D06H23M07S44
   Coding: 00A8DD
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY191251XZQ
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005 0313
   Serial number: 00002854456462182207
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Component: J527 SMLS MQB  005 0080
   Serial number: 00000023032104400679
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0073
   Serial number: 000308417318277 Dataset Number: V03935313MC 0001
   Coding: 8271567841
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 58E9751CE29480AA373-800C
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Dataset Number: V12345678AA V310
   Coding: 2B0D67E35DFFC728979C81A4614006800000000000B9C00024
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW37.rod
   VCID: 47CBA6603F2A1F52AE9-8012
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ Dataset Number: V03935272MG 0001
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA92278D-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 07A532806E8C000801887A0F5401000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2B03FAD08382DB32AA1-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5502
   Serial number: 09012020001767 Dataset Number: SET_FPA_MOD 0001
   Coding: 030900047F085700FB0002FE080F00010001070000000000000000000000
   GVL: 014E3C100000000040CC80000002480000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5BFE80277A9792569-802A
   Generator:
   Component: 4-01-02-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 E    HW: 1EA 959 442 E
   Component: MFL  H03 0219
   Serial number: 17036218123222100544
   Coding: AE2B00
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW37.rod
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000587514012
   Coding: 52A54640
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392FD09879DE79A228D-806C
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000587481913
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000417322781  Dataset Number: V03935341UB 0001
   Coding: 00150220D000048000001000
   Shop #: WSC 00030 935 00052
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 52FD8734C468AAFAC97-8006
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Dataset Number: V03935287HR 0001
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B121AC1E3CC4CA3BB-8020
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0371
   Serial number: 01081930001280 Dataset Number: V03935292JZ 0001
   Coding: 00000005090016C200207F07620000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 372BD6A04FCA6FD2DE9-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000423015792  Dataset Number: V03935341UE 0001
   Coding: 00150220DE00048000001000
   Shop #: WSC 00030 935 00034
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 51FF8838C16ED1E2F0D-8004
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0879
   Serial number:                Dataset Number: 5G0CV1v____ 0001
   Coding: 02731001FF0000004111010140880A231F0507E401200400CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323DE7B4A4A88AFAE97-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 CA    HW: -----------
   Component: ECE AS 22/23  --- 1810
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Serial number: 30000000250801 Dataset Number: RDKS_TinyQ_ 1017
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3829D59C42D460AAD73-806C
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Dataset Number: V03935246NT 0001
   Coding: 01040201C600201F000060
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1302
   Serial number: E80320004213340 Dataset Number: V03935349WG 0001
   Coding: 0000018811EEC028889F2C801030004400438000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW27.rod
   VCID: 3537DCA855C69DC2CC5-8060
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5F0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 Z001
   Serial number: 181027201414
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 6A8D3FD44CF8023A917-803E
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:47, VBatt start/end: 12.8V/12.8V)-----------
First impressions are good. Very good braking (without forcing the new brakes/pads/discs) and surprisingly the car goes 'perfectly' straight without any type of driving assistance,... but there is still work and more tests to do.
Now that it's sunny I install the windshield wipers. :mrgreen:
I removed them to install the DCC shock absorbers, etc...
Golf 7.5 DCC project. Connection. +30, +15, Running gear CAN lines, Rear left level sender to DCC unit. Fuse.
+30
+15
Running gear CAN Lines.
15A Fuse.
RL LS to DCC unit.
Previous info:
1- viewtopic.php?p=597574#p597574
2- viewtopic.php?p=603569#p603569
3- viewtopic.php?p=603711#p603711 , viewtopic.php?p=603723#p603723
Golf 7.5 DCC project. Coding. Basic Settings. Test.
After connecting the DCC system, the first diagnosis shows a large number of faults in the control units due to the battery disconnection and the installation of the new DCC system. Coding is required to clear all DTCs.
Applied coding.
DCC Coding (VCDS/ODIS)
Coding:
Byte27 Bit7 ... enable  (DCC installed)
Adaptation:
[VO]_Leuchtweitenregulierung:
[LO]_sensor_headlight_range_control_installed:	[VO]_front_and_rear
[LO]_1_Sensor_LWR:	[VO]_2-Sensor LWR
[LO]_Quelle_Hoehenwerte:	[VO]_CAN_Daempferregelung
Coding:
Byte4 Bit4 ... enable (DCC installed)     [LN]_damper control electronic:	[VN]_yes
Coding:
Byte12 Bit7 ... enable  [LO]_FPA_Funktion_DR: [VN]_not active [VN]_active
Adaptation:
14 -Wheel Damping Electronics ... enable
[VN]_Gateway_Component_List:
[LN]_Node_0x72: [VN]_not_coded [VN]_coded
Coding:
Byte8 Bits1-2 ... enable
[LO]_lwr_sensors:	[VO]_2_sensors
[LO]_Source_height_value:	[VO]_DCC
Basic Setting.
Address 14: Wheel Damping Electronics.
ODIS-S: Guided functions.
BASIC SETTING ... Vehicle liftted (axles extended)
Basic setting 4B. :arrow: viewtopic.php?p=582892#p582892
I drive a short distance to have all the sensors recalibrated due to the battery disconnect. I do a new ignition cycle and clear all the DTCs.
'In my case', I have two permanent faults left in the DCC unit (14 Address) that I must solve.
1- Wheel Damping Electronics. Basic Setting.
ODIS S.
To perform the Basic Setting it is necessary to lift the vehicle so that the axles are extended and the wheels are not in contact with the ground.
I had planned to do it on the platform of my trusted wheel workshop, but I preferred to do it with two jack stands and two trolley jacks because I wasn't going to work under the car, it would take me a couple of minutes, plus the 5 to 10 seconds in which ODIS S performs the basic setting.
I went to a place far from humanity, trolls and other divinities 😁, to avoid possible incidents as much as possible.
Warning:
Do not do what you see in the two previous images if you are going to work under the car, additional safety measures are necessary.
I click on yes and the basic setting is done successfully in the blink of an eye, I didn't have time to take a screenshot.🤷‍♂️🤭
2- Wheel Damping Electronics. Invalid dataset.
ODIS E
I don't know why the data set on my DCC unit 5Q0907376C (coming from an Arteon according to the eBay seller viewtopic.php?p=597558#p597558) is invalid.
I look in MIB Solution, and luckily there is a different dataset also coming from an Arteon. I downloaded them and did the data transfer with ODIS E, as usual.
Note:
I first did the data transfer with the Golf (clubsport) dataset that is on the VCP servers, but logically it doesn't work either for DCC unit 5Q0907376C (Slider).
🧙‍♂️OK!
VCDS Autoscan.
Sunday,07,April,2024,14:06:06:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: DCC. OK!
Mileage: 53083km-32984mi   Repair Order:
Scan: 01 03 08 09 10 13 14 15 17 19 29 39 3C 42 44 4B 52 5F 65 6C
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 53083km-32984miles
14-Susp. Elect. -- Status: OK 0000
   Coding: 01FA6AA134202170477B060560CA2580562C84E26006A4733420F08A40AA430B00000012121212B835351919323200
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 31051841350252 Dataset Number: V03935317XE 0001
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 07A532807E8C000801887A0F5401000080000000
   Coding: 030900047F085700FB0002FE880F00010001070000000000000000000000
   GVL: 014E3C100000000040CC800000024C0000000000000200000000000000000000
   Generator:
   Coding: AE2B00
   Coding: 52A54640
   Coding: 010000
   Coding: 931F0000
   Coding: 00000005090016C206207F07620000000000000000000000000000000000
   Coding: 090000
   Data carrier:
End----------(Elapsed Time: 01:45, VBatt start/end: 14.5V/14.5V)-----------
Previous update of the GW dataset for Slider. :arrow: viewtopic.php?p=602020#p602020
Related (MODE): viewtopic.php?p=577888#p577888
Test.
:lol:
- In Comfort mode, filters road irregularities with notable gentleness. For my personal taste, perhaps the maximum Comfort setting makes the suspension a bit bouncy for good roads at high speed, so I think the maximum Comfort setting is only recommended for really bad roads, like rural roads in a very bad state of conservation (like the image above).
- I love all the possibilities with the Slider, allows you to adjust the suspension for any type of road with relative precision (depends on the driving capabilities/skills/experience/knowledge of each individual). Those who have high driving skills will greatly appreciate this type of electronic damping.
- Considering that our Golf had a 'standard' suspension from the factory (which is already very good), I really appreciate the Sport mode setting for highways or sporty driving, the driving becomes very precise. I like the maximum Sport setting, it brings back memories of an S3 that I had in the past (not the same, but that jumps out in my mind).
- The good handling of the car is not lost in any setting of the driving profiles, even in the maximum Sport setting the/your back will not suffer due to the irregularities of the road.
On the other hand, the MODE button on the center console now makes more/real sense, you can switch from one driving profile to another quickly, which is very convenient for roads that have small sections with many irregularities or in poor condition and the most of the route/road is in good condition.
Works Wonderfully!💖
https://www.youtube.com/watch?v=hzryq-i_ukg
Currently I prefer this suspension height, I have already had other cars with very good and low suspensions that I will not have again. The laws of physics and other more mundane laws are inexorable.🤷‍♂️
Note:
I will check the geometry/alignment of the wheels according to erWin, in about 1000-2000 kms.
At the moment and surprisingly the car feels very good in this sense, it goes in a straight line perfectly, I will see in future checks what happens with the wear of the wheels/tires.
Flashing DCC unit 5Q0907376B SW_121 to 5Q0907376C SW_130, and transferring the data sets for Slider availability.
As you already know, I had two DCC units purchased on eBay with the same HW, once I have one of them working 'perfectly' for Slider in our Golf (previous post), I proceed to load the same SW and dataset to the other.
Video (process): :arrow: :arrow: :arrow: https://www.youtube.com/embed/mdIaO3WXu ... autoplay=1
Do you want it? It is for sale.
Cheap. Contact by PM.
https://www.youtube.com/watch?v=hzryq-i_ukg&t=65s
Golf 7.5 New original 'Blue' rear brake calipers. New brake pads. Brake fluid renewal.
Wonderful spring days.
- This change of new blue rear brake calipers is a cosmetic issue, they are the same size as the factory ones, but the same color as the new original front ones that I installed in the DCC project.
- I install new rear brake pads, included in the set of parts I purchased.
- I do not renew the factory rear brake discs because they are in good condition.
- I renew the brake fluid.
- I clean the original factory dust from the rear axle.🤭
Installation according to erWin (bolt torque, bolt renewal).
I do the activation-deactivation of the EPB with VCDS.https://www.youtube.com/watch?v=C9AcboaVGzY
Size.
Featured images of the process, shortened the images of the right side because they are the same as the left side.
Left side.
90Nm + 90º
35Nm
35Nm
Bleeding valve, 10Nm. Thin coat of assembly paste to the thread of the bleeding valve/screw.
A little look. Opening the hood/bonnet.
Right side. Complementary images.
Wheel cover cap. :arrow: viewtopic.php?p=603190#p603190
Need cleaning.
I do a road brake test with an ABS regulation. Everything seems normal, maybe the new brake pads need to adapt to the brake disc. The brake pedal feels normal.
I renew the brake fluid following the erWin/following procedure but with one-way valve and ultra-clean filling syringe.
The brake pedal feels normal/PERFECT.
VCDS Autoscan.
Sunday,14,April,2024,12:02:42:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: REAR BLUE BRAKES. BRAKE BLEEDING. NEW BRAKE FLUID. OK!
Mileage: 53329km-33137mi   Repair Order:
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 53329km-33137miles
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: AE2B00
   Coding: 52A54640
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Data carrier:
End----------(Elapsed Time: 01:48, VBatt start/end: 12.7V/12.7V)-----------
https://www.youtube.com/watch?v=ycwtqqhV6UE
Sometimes the brake fluid level represents a real uncertainty for the few adventurers and common mortals who dare to open the hood/bonnet, especially if the brake fluid is new/clean.
Opening the brake fluid reservoir cap is not an option for these adventurers, lest something break or get dirty with something dangerous.
In daylight it is even worse, ... please do something about this to solve it. :lol:
As incredible as it may seem, I forgot to do the diagnostic protocols with ODIS after all the tests.🤦‍♂️
Done this morning.
Also the readings of the whole vehicle with VCDS.
Let's see if next time I don't forget to take the SD card to update the navigation maps at home... 🤷‍♂️😊
After all, a car is just four wheels and a steering wheel.
https://www.youtube.com/watch?v=7kiPcUqBJuA&t=58s
Considerations about the latest improvements in our Golf 7.5 Ready2Go.
Brakes:
Factory brakes and 'related' driving aids/assistants are good ...having said that:
- The braking improved significantly when I changed the wheels from 15" to 16" with greater tread width.
Changing wheels to a larger size is better than changing brake discs to a larger diameter with the aim of achieving better braking.
- After a few kilometers in which the new pads have adapted to the four brake discs, braking with the 312 mm front brake discs is pleasantly secure in our Golf 7.5.
Edit after a few more kms:
Powerful braking ...💪😲... I will have to be careful with the inertia so that my eyes do not get stuck against the windshield, hmm... I think with the 288mm front brakes it would have been enough.😄
Adaptive chassis control. DCC:
- I am testing/investigating/enjoying its functionality, and without a doubt, the Comfort MODE is fantastic, a magic carpet.😅
- I think that for now and for the Individual MODE I will leave the Slider preset at the maximum Sport setting (sport +2). I suppose the spring weather these days influences this decision. I will set the Slider to another setting when asphalt conditions require it.
- I will use the MODE button more often, which is actually the most fun thing about DCC.😊
Although it is not necessary, I will soon replace the 110A Alternator with the 140A one, it's just a pending task and because the purchase of the 140A Alternator was a real bargain. Hope everything goes well.🤷‍♂️
https://www.youtube.com/watch?v=RplqJbVbgZI&t=29s
Golf7.5. MIB2.5. Maps update. 5NA919866ET , 2024-2025.
- Updated maps can be downloaded from the VW website, you must be registered and log in.
- Click on your myVolkswagen logo (top right of the screen) and go to/click other themes or more themes or something like that (depends on language).
- On the next screen you have the maps update. Once you have indicated the car model and the infotaiment-navigation system, you can download the updated maps.
- The download takes some time, up to 45 minutes, depends on your computer/device and connection speed.
- Unzip (7z ) the zip file and copy the 'maps' folder to the original VW 32GB SD-CDA card.
- The SD-CDA card must be empty.
PDF: https://www.myvolkswagen.net/weatweb/fe ... 202045.pdf
Before.
After.
You must reload the database with radars/speed cameras if you have them.
Note:
1- Some time ago I had to change the SW of the infotainment system so that everything worked correctly. From 0891 to 0879. viewtopic.php?p=589440#p589440
With the new/good SW 0879 I have to use the original 32GB SD-CDA card for updating maps, so that the system can read the data. With the old/bad SW 0891 I could use any type of SD card (>32GB) for maps update. I think it depends on how the software is "manipulated".
2- If for whatever reason you need an original 32GB SD card with updated maps (V19 Europe, 5NA919866ET) and on which you can load the following map updates (2026/27) for MIB2/2.5 VW infotainment systems (original or manipulated), the ones sold on Ali work.
I bought one to test it and to have a second physical medium to update the maps in case the original SD breaks or stops working. The maps are exactly the same as the download from the official VW website. Testing extreme conditions (download, upload/reload, cold, heat, magnetism) and everything continues to work perfectly.
Manipulate sounds more legal than hack, considering that some original SWs were a bit of a disaster.
https://www.youtube.com/watch?v=thJgU9jkdU4&t=275s 🔱
Golf 7.5. New 140A Alternator/Generator. From 110A to 140A.
From 04E 903 015 to 05E 903 026 Q.
Installation according to erWin. Torques, etc...
Some prior information that you should keep in mind if you are going to do the same or something similar...
- Voltage regulator. Basic setting/Adaptation: viewtopic.php?p=594150#p594150
- Installation related: viewtopic.php?p=594180#p594180
Installation. Highlights.
A little cleaning in these areas, although there is a lot of pollen suspended in the environment and it is impossible to leave it completely clean, also, unfortunately for me, I forgot to close the driver's window completely and I will have to remove the dust/pollen with the duster again when I finish this installation.
In the previous image the generator/alternator cable, with the ammeter you can check that the generator charges according to the consumers.
Video here :arrow: viewtopic.php?p=594095#p594095
At the first engine start I see that something new is happening (I'm starting to think I've broken something 😄), the idle is unstable between 1000-1300 rpm, it stabilizes after the first 5 to 10 seconds and when I check the voltmeter I see that the new 140 A alternator is generating charge... 14.1 volts (in this case).
This happens every time I do a new ignition cycle. It must be solved.
I connect the diagnostic tools (VCDS, VAS6154, etc.), clear all DTCs due to battery disconnection, and the diagnosis returns two faults that are related, one on the engine and one on the Gateway, as shown below.
Again I start to think maybe I forgot to connect the LIN, but I was pretty sure I heard and felt the connector click.😊
To solve this fault/s it is necessary to do the Adaptation/Basic setting of the voltage regulator, as you have seen in the video linked above.
It takes 10 minutes of waiting... then I reconnect the VAS according to the guided function and when I click on 'repeat' the basic setting has been successfully carried out.
I clear the faults, cycle the ignition again, start the engine, and everything works as it should. Perfect idle, as usual.👌
New diagnostic protocol, and VCDS Autoscan.
I take the car for a walk to verify that everything is working correctly.
Monday,22,April,2024,19:44:51:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: NEW 140A ALTERNATOR/GENERATOR OK!
Mileage: 53696km-33365mi   Repair Order:
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 53696km-33365miles
Readiness: 0100 0000
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Component: 5-01-14-01-04
   Coding: AE2B00
   Coding: 52A54640
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 ET    HW: -----------
   Component: ECE AS 24/25  --- 2210
End----------(Elapsed Time: 01:47, VBatt start/end: 13.4V/13.3V)-----------
From.
Generator:
To.
Generator:
+ (previous post)
Data carrier:
https://www.youtube.com/watch?v=9uMtnH7cABg&t=100s
Locked
