Fitting a BMC Induction Kit - Updated Pictures 12/08/2008
spring clean
I have had my bmc filter for about 10 months now and my car doesn’t seem to pull as much as it did so I think it time for the filter to be cleaned. Only Problem is I don’t know how . Can anyone enlighten me to what I need and how I clean the filter.
After reading about this induction kit Im also thinking installing one too, but I keep thinking about my car insurance.
I found some information about the different ones you can get. The site is
http://www.bmcairfilters.com/infoCDA.asp
I’m pretty sure it’s the CDA70-130 code for the Polo GTI as that’s the one for the Lupo GTI. Not to sure about the warning on there thou.
Your right about the filter been the same one as for the Lupo GTi.
As for the warning, don't listen to it. Fitting it is about a 20 minute job, including removing old air box. Just plan where you want to get your air feed from! And as for not road worthy. That is down to the fact that the standard air box has the crankcase breather feeding into it, where as the BMC doesn't. Simply buy a crankcase breather for about £10 and your car is road legal. If you want, just make sure your crankcase breather pipe has a filter on the end for when you have an MOT.
Simple
Mat
Simple
Mat
I bought mine from larkspeed about 18month ago. The sound is just right if you ask me, but it varies on how you fit your BMC. Depending on where you get your air feed from and the typw of piping depends on the sound and note produced. There's definately more pull in my car than the standard filter!
The crankcase breather can be bought from most places. If you just measure the diameter of your breather tube and then go and choose your filter. Mines the BMC one but i've had to use some tubing from a snorkal to join them together!
Mat
Mat
Hi there,
First off thanks a lot to blackgti for your great guide! (without which I would have had difficulty fitting my BMC, as the instructions that came with it were practically useless).
Secondly, I’m a complete novice and have never done anything like this before. So I thought I’d try and add a little bit more detail to this guide to help any others like me.
Things I needed to fit the BMC
10mm Wrench
10mm Spanner (used to hold the nut on the bottom of the BMC clip while you tighten the bolt on the top).
5mm Allen Key
Flat Head Screwdriver (preferably a ‘stubby’ as that engine bay is pretty cramped)
Hacksaw
40mm length (approx) of Copper Pipe
I used 15mm diameter pipe (same pipe that you should see going into and out of the radiators in your house) However this was slightly too thin to fit snugly in the crankcase breather pipe so had to use a spare bit of Brake Servo Rubber Hose which fitted perfectly over the copper pipe and went tightly into the crankcase breather.
Difficulties I had while fitting
The hardest part for me when fitting my BMC was removing the OEM air intake piping. As I couldn’t get good access to the bolt securing it to the chassis. That was before I realised that Power Steering fluid reservoir could just be slotted out. Once this was out of the way the bolt was easy to remove.
I also had a little bit of difficulty getting the OEM air box off. That was because I tried to removed the air box in one piece, I just undid all of the visible bolts that secured it and struggled trying to yank it out for a few minutes with no joy. I then opened the air box up and found another bolt that secured it to the chassis. Once this was undone the box came out easily.
Other than that the fitting was real easy (following blackgti's guide) and in total took little over an hour.
10mm Wrench
5mm Allen Key
Hacksaw
- Sponsor
That pipe doesn't go into the manifold, it just goes into the engine cover.Omz_6N2 wrote:Quick question, There's a pipe that goes into the Manifold from the Original air feed, what would replace that after fitting the BMC ??
You just slot that out of the engine cover, nothing needs to go over the end of that pipe
Nice DIY-guide, but just 1 tiny piece of critic, why place the piping over/on the exhaust manifold? The manifold get's hot as hell, which heatens the pipe, and therefor the inlet-air which enters the filter and engine. And hot air has less density, and therefor decreases performance (a tiny bit, but any bit is a bit )
