Instrument Cluster swap, need information
Re: Instrument Cluster swap, need information
Is this procedure of swapping clusters a simple case of plug and play? Or do you need to re-code the new one with the mileage etc.?
- Ugabista
- Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Hello everybody.
Firstly, I want to congratulate for the excellent forum to have here
I have thought of changing my cluster to an MFA +, but my car is a diesel, with the 1.6TDI engine 90hp. Is it possible? I've read somewhere that the Amarok TDI gives someone confirm?
Thanks in advance
Thanks in advance
- Ugabista
Nobody knows
Can be done but it is very expensive depends on how long you will be keeping the car for
- Ugabista
Yes of course, but I want to know is if it is Plug & Play the Instrument Cluster Vw Amarok TDI: 2H0920871AX in my 6R 1.6TDI CAYB Confortline 2009...v896 wrote:Can be done but it is very expensive depends on how long you will be keeping the car for
As I understand its not just a simple plug in play its requires coding from VCDS software.
Fitting a Amarok cluster is not straight forward, but almost. You need to need to modify the eprom to have wheel circumference, braking fluid floater, fuel gauge and pictogram fit the Polo. But it can be done:
The eeprom has to be edited, with suiting software. There are no guides to do this, currently only potatodog has the tools and needed custom eprom.
Ok... thank you very much for the info. potatodog, Where? Germans forums?
For those who may be interested, do you have a link to contact?...
regards
- Ugabista
Do you have a link that forwards?
Greetings
Greetings
- Ugabista
I read somewhere that this will give the 1.6TDI the 6R ...
http://www.carsystems.pl/polo-6r-instru ... id487.html
smg_shardul
- Drives: Polo 6R
i want to swap instrument cluster anyone have idea how to swap?
govindsharma
- Drives: polo 1.2 petrol HighLine
Good Afternoon all of you how wants to swap Instrument Cluster.I will tell you steps that needs to swap cluster from lowline to highline GTI.
1. Step one to transfer data from old cluster to new like Km driven service record etc.
2.Step second which is very important must be done in VW service center is online coding of key with immoblizer.Whole process takes about 7 to 10 minute.If vw personel are friends than it will be done in no cost otherwise they will not do this job.In this step data from vw server is taken and feeded to new cluster so that key work otherwise car will not start.
