POLO 6R. HEATED SEATS. OEM.
Re: POLO 6R. HEATED SEATS. OEM.
federicodrdpro wrote:Hi! Polo 6R OEM thermo elements are very rare and more expensive. You can buy the Seat Toledo/ Skoda Rapid thermo elements for your Polo. They fit perfect in VW Polo 6R. I mounted them and they are perfect! 8)
You can buy them here: http://www.skodaautoteile.de/shop/rapid ... 3001880736
They are the economic OEM thermo element you can buy for your Polo.
Thank you very much for the information (x1000). 8)
CNK wrote: Did you have to iron seats after this retrofit? :)
Image... :lol:
RUM4MO wrote:
federicodrdpro wrote:Hi CNK :), Do you mean if the seats have a different confort after mounted the heated elements?
The comfort is same of before. :wink:
No that is not what he meant, the English language - it can cause problems, "iron" in English = "ferro" in Italia ! ie ferro da stiro
Sincerely thanks for explanations (as ever), You know that although I am kidding too many times :oops: am a faithful follower of you.
federicodrdpro
Drives: White Polo 6R TDI
Post by federicodrdpro »
Thanks! Now I undertsand :mrgreen:
The seats after retrofit are like before. I didn't have to iron seats. The cloth is very tense and you don't need to iron the seats! :wink:
ciclo wrote: Thank you very much for the information (x1000). 8)
You are welcome :wink:
CNK
Drives: 6R
Post by CNK »
Hello, I mean something like this:
or
:lol:
Asamoli
Drives: 1.2 TSI (105) SEL polo 6r
Post by Asamoli »
Cheers for the info. Where did you buy the buttons for the dash?
Sent from my XT1572 using Tapatalk
federicodrdpro
CNK wrote: Hello, I mean something like this:
Yes, I understand! :)
You don't need to iron your seats! ;)
Asamoli wrote:Cheers for the info. Where did you buy the buttons for the dash?
I buy it from Aliexpress.
Federico
hmmmm heated rear seats. OEM :mrgreen:
federicodrdpro
iichel wrote:hmmmm heated rear seats. OEM :mrgreen:
Hahaha, rear heated? Yes, if mount the front heated is not enough for you :P
now if i pick up pizzas, i can only bring one because the passenger seat is only heated. with heated rear seats. imagine the possibilities.
Luksas
Drives: 6R
Post by Luksas »
Hello Guys
Few days ago I retrofitted heated seats. Everything works but I couldn't code the comfort module.
Can't see option about heated seats. My module is 6R0 937 087 H coding: 3CB029BF08A10000002808003D2B0CD80040000F60060000200000000000
Can someone send print screen with this option from vag com ?
Thanks a lot, Lukas
byte 15 bit 4, set to 1
federicodrdpro
What is this coding?
Activates the heated seats.
Usually it is active from the factory even if the heated seats are not installed.
Luksas
Drives: 6R
Post by Luksas »
Thank you guys, but still the same.
The reason why I'm trying to code the module is that the seats are working even when ignition is off.
If I understand well, module should send message "switch off" when I switch the ignition off.
This is how it's looks like my byte 15
Looks like bit 4 its active anyway.
Probably I'll change plus feed in fuse box.
Just tell me if I'm right ;)
correct!
but officially the heated seats are on terminal 75, which is like a terminal 15. so it should be an ignition switched plus anyway!
emmanuel.hadji
Post by emmanuel.hadji »
I did the retrofit as well and would thanks for all the info found here.
I'm now stuck with the same step than the one mentionned by Lukas : seats able to work while ignition is off.
I my case slot 47 was not feed in the fuse-box and the only free slots available were permenent plus.
I'm a bit lost on how to get electrical connection in a clean way with an ignition switched plus within the fuse box ??
Hoppe this isn't a to naive question.
Help would be greatly appreciated.
